by Discovery » 05 Oct 2016, 10:05
Hi Bo,
Have you explored the Webradios section of the library yet? Strictly speaking, FM radio as such is not available but many radio stations provide a stream of their output which you can find and receive.
True FM requires an FM tuner. This outputs an analogue signal so is of no use to a Pi. On my second system, I have an Audiolab 8000T tuner (superlative sound) and I feed the output directly to a power amp via a passive pre-amp. The other input on the pre-amp is a DAC.
Streaming radio is usually of acceptable quality for most purposes and requires no more equipment or outlay than you will already have in place for your Pi. I personally connect my Pi with ethernet rather than wifi and have had no gaps, glitches or clicks since doing so. If you don't have ethernet near your Pi, invest in a pair of power line LAN plugs - this works fine for me.
Let us know how you get on.
Regards,
Trevor
