foobar2000 stream to Runeaudio?
Postby heffer » 06 May 2014, 02:02
Hey all.
I don't have a system running yet, i just ordered my raspberry pi with a hifiberry but I've been doing a whole bunch of research. So even though the hard drive that I will be plugging in will have most of my music, it is also used in my wdtv live. To avoid getting up as much as possible to switch devices, is it possible to have foobar2000 stream to RuneAudio?
heffer
Re: foobar2000 stream to Runeaudio?
Postby ACX » 06 May 2014, 20:26
If you use three different devices to play music from the same source (your music collection is located on the same drive), then a NAS should be the ideal solution to your needs...
Postby heffer » 07 May 2014, 14:43
heffer
Postby ACX » 07 May 2014, 14:59
Not yet, sorry. It will be in the future, and you could use this plugin:
http://www.foobar2000.org/components/view/foo_upnp
although it would be arguable in terms of quality and usability.
Users browsing this forum: No registered users and 39 guests
