Getting a DAC+ setup
Re: Getting a DAC+ setup
Postby audio007 » 27 Sep 2016, 18:34
I have chhecked the debug file and still has the DAC error:
5.732671] snd-rpi-hifiberry-dacplus sound: ASoC: CPU DAI (null) not registered
[ 5.732700] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
[ 5.745326] snd-rpi-hifiberry-dacplus sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 5.745352] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
[ 5.915127] pcm512x 1-004d: Failed to reset device: -5
[ 5.915252] pcm512x: probe of 1-004d failed with error -5
I will investigate more and post again later.
audio007
Postby audio007 » 27 Sep 2016, 19:10
Reimaged the SD card, nano altered the config.txt file to 'enable' dacplus.
Still no DAC available in the UI
the debug lines are now:
5.830791] snd-rpi-hifiberry-dacplus sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 5.830814] snd-rpi-hifiberry-dacplus sound: snd_soc_register_card() failed: -517
[ 6.021065] pcm512x 1-004d: Failed to reset device: -5
[ 6.021300] pcm512x: probe of 1-004d failed with error -5
I will try my Volumio SD card and see if that sees the DAC
audio007
Postby audio007 » 27 Sep 2016, 19:36
Replaced Rune SD card with Volumio SD and the DAC was available and played.
Not sure what to do now?
audio007
Postby audio007 » 28 Sep 2016, 08:47
Found the problem and it due to my stupidity!
I had uncommented the wrong line, the 'dacplus' one and not the 'digi' one.
Thanks to all who tried to help.
audio007
