[solved] git pull not possible
Postby sykodad » 10 Jun 2016, 19:33
I just flashed a sd card with the latest RPi2-image. Unfortunately, I cannot update the system with "git pull":
[root@runeaudio http]# git pull
Updating 71f5236..e6f6474
error: The following untracked working tree files would be overwritten by merge:
command/mpd-watchdog
Please move or remove them before you can merge.
Aborting
Regards,
Jan
sykodad
Re: git pull not possible
Postby hondagx35 » 10 Jun 2016, 20:39
Postby sykodad » 11 Jun 2016, 11:14
Hello Frank,
great, that did the trick. Thank you.
Regards,
Jan
sykodad
Postby waves » 28 Aug 2016, 16:54
waves
Re: [solved] git pull not possible
Postby hondagx35 » 28 Aug 2016, 21:19
Postby BorGreiner » 13 Nov 2016, 16:19
Um... Did I break something? :)
[root@delovna www]# git pull
fatal: unable to access 'https://github.com/RuneAudio/RuneUI.git/': SSL certificate problem: certificate is not yet valid
BorGreiner
Postby AxelFendersson » 16 Nov 2016, 13:16
AxelFendersson
Postby BorGreiner » 17 Nov 2016, 08:37
date --set="17 November 2016 08:36:00"
before doing git pull, solved the issue, many thanks!
BorGreiner
