Guide for using HDMI Display with RPI 3 B+
Postby DNB » 17 May 2017, 00:58
Good Morning,
I am building a audio player as a father/daughter project using a RPI 3 B+. We would eventually like to use the 7" touchscreen display, but for now we will be using a spare HDMI display I have.
I would like my daughter to be able to control the RPI 3 B+, running Rune Audio, using the display attached to the RPI, rather than using RuneUI on a separte device.
Is there a guide to how to do this?
I have read this trouble shooting guide http://www.runeaudio.com/documentation/ ... eshooting/
The only note I see is the line :"Rune UI can now be invoked in a browser", under "Normal Boot Sequence"
Is it a matter of simply having the display connected to the RPI, and the UI will be displayed?
Many thanks for any assistance.
DNB
DNB
Re: Guide for using HDMI Display with RPI 3 B+
Postby hondagx35 » 17 May 2017, 12:20
Postby DNB » 17 May 2017, 23:03
Many thanks for your reply!
Thats just the information I was looking for. Thanks for your assistance.
I will report back with an update!
DNB
Postby DNB » 19 May 2017, 23:21
Update:
Downloaded the image
Wrote the image to sd card using Win32discimager
inserted card into RPI, connected ethernet, hdmi cable then power supply
red light comes on, hdmi display shows "rainbow square"
nothing else
cant see rpi in the list of connected devices on my modem/router
any suggestions?
many thanks
DNB
Postby DNB » 19 May 2017, 23:59
Tried reformatting the card using sd card formatter
then reloaded img file
still only red light
no lights at the ethernet port
DNB
Postby hondagx35 » 20 May 2017, 21:12
please try my latest test image.
Postby DNB » 22 May 2017, 09:46
Downloaded 0.4, as suggested, and it works!
Many thanks Frank!
Used putty to connect via ssh to the RPI, to edit .xinitrc to activate the mouse pointer. Succesfully connected to root using the usernam and password in docs.
Unfortunately I have no idea how to edit .xinitrc :)
Could someone tell me the commands to edit the file? First time putty/ssh user!
Thanks again!
DNB
Postby hondagx35 » 22 May 2017, 14:10
Postby DNB » 23 May 2017, 10:35
Many thanks for your assistance.
I used the nano command to edit the .xinitrc file.
When I rebooted the RPI i had zero output from the HDMI (blank screen).
The RPI still booted. I checked the .xinitrc file and the mouse pointer was on, but no output.
Connected via the RuneUI. Could modify settings etc.
Entered wifi details and Spotify premium account details while still connected via ethernet.
Checked Spotify functionality while still connected via ethernet. Spotify would play, but volume was very low and volume control was disabled.
Disconnected RPI, removed ethernet cable, and rebooted.
Connected to my HiFi Amp via 3.5mm jack. Spotify would play, no volume control via RuneUI but can control volume with amp (of course!)
So, we are nearly there! I just need to get the display working! Any ideas?
Many Thanks
DNB
DNB
Postby DNB » 26 May 2017, 02:56
OK, I have confirmed: Changing the .xinitrc file to read "use_cursor yes" from "use_cursor no" kills my HDMI output completely.
When i change the .xinitrc file back to "use_cursor no", I get HDMI output again.
Can anyone help with this?
Many thanks!
DNB
DNB
Users browsing this forum: No registered users and 42 guests
