[phpBB Debug] PHP Warning: in file [ROOT]/mobiquo/hook/function_hook.php on line 86: A non-numeric value encountered
Guru Meditation after fresh install when accessing playback : Raspberry Pi • RuneAudio Forum
Postby Cilahn » 18 Feb 2023, 23:33
i'm new to rune and just installed the 0.3 release on my pi B+. I can access the gui and use the menu to access the settings, network, debug, credits. Sadly when i try to access the playback, library or playlist menu i get a guru meditaion error:
Software Failure. Press left mouse button to continue.
Guru Meditation #0000022.65045032
This could have happened because of one of the following reasons:
BAD REQUEST
The url you are trying to access does not exist.
BUSY SYSTEM
System is taking too long to process your request.
My library is mounted via nfs and is currently updating. Am i doing wrong or is this a bug?
Regards,
Cilahn
-----debug info -----
###### System info ######
Linux version 3.12.26-1-ARCH (nobody@root-armv6-copy) (gcc version 4.8.2 20131219 (prerelease) (GCC) ) #1 PREEMPT Fri Aug 8 17:40:14 MDT 2014
system time: Sat Feb 18 23:19:31 CET 2023
system load: 0.17 0.17 0.44 3/88 8290
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
Cilahn
