HDMI output flickering
Postby Archino » 26 Aug 2017, 11:49
I just started 0.4 Beta on PI3. It boots up, but from the first second, the connected screen (normal monitor with HDMI-VGA adapter) keeps flickering. I can somehow see a picture, but something seems to be wrong with the timing. I have also a Pifi digi+ connected at the same time.
Its not a HW issue, because if I boot with another SD card with Libreelec, everything works fine.
Any ideas?
Thanks,
Archi
Archino
Re: HDMI output flickering
Postby hondagx35 » 26 Aug 2017, 14:00
Postby Archino » 26 Aug 2017, 14:48
Not yet. Thanks for the hints anyway.
When I do this the screen stays dark. I also tried disabling CEC and hdmi_save without success. Later I will look into the config. txt of Libreelec and see whats the difference.
Also found some LIRC settings in the config. Maybe I get also that part running. Stay tuned :-)
Archino
Postby jfloresqui » 18 May 2019, 02:53
Hi.
I am using a generic HDMI to VGA converter, tried the parameters proposed by hondagx35,and voila!, the Rpi Zero W works fine.
After 4 hours of usage works fine.
I hope this will be useful for you.
Note: For your reference, the HDMI-VGA converter I use, does not use external power.
Regards.
jfloresqui
Users browsing this forum: No registered users and 52 guests
