HEATSINKS ?
Re: HEATSINKS ?
Postby Discovery » 22 Jan 2017, 21:32
Discovery
Re: HEATSINKS ?
Postby TommyBoy » 22 Jan 2017, 22:05
Did you see the link i posted ?
It reveal some times big difference in read out temperature.
Please direct me to the frost update ?
What is it about ?
TommyBoy
Re: HEATSINKS ?
Postby Discovery » 23 Jan 2017, 00:04
Frost_dk's mods give much better sound clarity, and also slow the processing down a little so might benefit your temperatures: tweaking-the-audio-performance-rpi3-t4301.html Have fun! Ask if unsure.
Yes, I read the article. Regardless of measurement inconsistencies, my 'finger test' still says 'warm'...
Discovery
Re: HEATSINKS ?
Postby TommyBoy » 24 Jan 2017, 11:18
my temperature issue is solved
cause1 : shiny heatsinks do not radiate heat as IR
cause2 : system inside closed case with no moving air = result same as no heatsink
cause3 : inside of case also very shiny = also reflect heat, so outside of case was Cold, inside burning hot.
fix1 : changed heatsinks to larger Black coated types = radiate heat IR, even if air dont move.
fix2 : painted box Black mate inside pick up IR, and drilled air holes in case.
NOW the CPU is 22 C colder and i am happy.
TommyBoy
Re: HEATSINKS ?
Postby Discovery » 24 Jan 2017, 15:08
Good news. :)
I do wonder why vendors sell heatsinks with colours other than black, when matt black surfaces radiate heat better than any other.
Discovery
Re: HEATSINKS ?
Postby TommyBoy » 24 Jan 2017, 15:39
on a non painted heatsink there is no difference in temperature IF there is plenty of moving air !
but huge difference if the main transport of heat is done via RADIATION
(in a non air movement application)
paint or anodizing cost Money.
TommyBoy
Re: HEATSINKS ?
Postby Discovery » 27 Jan 2017, 21:54
Hi TommyBoy,
You made me worried ;-) so I bought some heatsinks for my Pi. It's now down to 27 deg, after extended playing but then it wasn't that hot in the first place. Still, better safe than sorry! :D
In fairness, I should advise that my Pi is currently running naked in the open. This is as a result of fboe's mods to add new power regulators. However I am about to put my LPS, RPi and the new regulator board in a large dedicated aluminium case so the heatsinks are to ensure it continues to run cool in a vented enclosure. And, of course, I'll be spraying the inside (and outside) of the case matt black before I complete it.
All the best,
Trevor
Discovery
Re: HEATSINKS ?
Postby TommyBoy » 28 Jan 2017, 12:25
hi Trevor, i am super happy you could use my experiance for something :-)
I just updated this page
http://webx.dk/oz2cpu/raspberry_player/ ... player.htm
you can see my super large heatsink
TommyBoy
