HELP CONNECTION
HELP CONNECTION
Postby lifegoeson » 20 Nov 2015, 16:19
Hello
Can anyone tell me why i cannot connect to the raspberry and RuneAudio from my MAC by using only the wifi?? it works only if the computer is connected to the network with the cable...!!! How can i say... if i use http://runeaudio.local doesn't works without the Cable plugged to the router ..
Thank you
lifegoeson
Re: HELP CONNECTION
Postby lifegoeson » 20 Nov 2015, 16:22
i forgot to say that the wifi dongle works well... i settled all parameters of my network ( network name and pw ) Both connections , cable and wifi are well..
lifegoeson
Re: HELP CONNECTION
Postby hondagx35 » 20 Nov 2015, 17:12
Hi lifegoeson,
first it would be good to know which Pi (model) you own.
Please try to use the ip address instead of http://runeaudio.local.
If both interfaces are active avahi (the Apple Zeroconf service) may not work correct.
Re: HELP CONNECTION
Postby lifegoeson » 21 Nov 2015, 15:07
Hello Frank
Thank You
I own the P2 model B
You are suggest me to chose between cable or wifi for the connection ?
And if i set up the wi fi parameters ( under network menu ) do the raspberry keeps them after shout down and reboot? I would like to control the system by using my Imac lat top via wi fi ..basically this is the main issue
Thank you
Lifegoeson
lifegoeson
Re: HELP CONNECTION
Postby hondagx35 » 21 Nov 2015, 18:48
