Help! mount.nfs: access denied by server while mounting
Re: Help! mount.nfs: access denied by server while mounting
Postby SomeGuy » 12 Apr 2015, 15:30
Error messages abound regardless of connection type.....
I'm using a Mac & my music is stored on a WD MyBookLive, should I be using SMB/CIFS, SMB/CIFS (OS X share) or NFS?
It seems I am unable to proceed regardless, the homepage makes this seem like a cakewalk.
SMB/CIFS - mount error(22): Invalid argument Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
SMB/CIFS (OS X share) - mount error(22): Invalid argument Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
NFS - mount.nfs: access denied by server while mounting 192.168.0.4:/Public/Music
SomeGuy
Postby ianhaynes » 12 Apr 2015, 16:04
It's a long shot but I needed to access my NAS drive via name rather than ip address.
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby SomeGuy » 12 Apr 2015, 16:48
Yeah, I tried that, but it wasn't interested then either. Thanks though.
SomeGuy
Postby ACX » 13 Apr 2015, 12:31
I personally used a WD MyBookLive World Edition in the past and I was using that in NFS without any issue. Just configure the right permissions on the NAS, you have to specify the allowed IP addresses for NFS.
Postby SomeGuy » 13 Apr 2015, 17:47
Thanks for helping out.
I've just been having a look at the MyBookLive & I can see that Volumio is currently showing as a MediaPlayer under the DLNA section:
Volumio: root Windows Media Connect compatible (MiniDLNA) b8:27:eb:ef:b4:37 192.168.0.x
Is this likely to be blocking access from RuneAudio (same IP address) & if so, how do I get rid of it?
SomeGuy
Postby SomeGuy » 13 Apr 2015, 20:00
I'm now up and running after starting over again. No idea why but it went swimmingly. Thanks all for your attempts to guide an idiot through this.
SomeGuy
Postby Diskdoctor » 07 Feb 2016, 22:39
In case it's of help to others:
I was having similar issues mounting my WD My Book Live. By adding nfs to the "remote directory" path I was able to mount it as NFS. So my runeaudio settings look like:
Fileshare Protocol: NFS
IP address: SmithMyBookLive
Remote Directory: nfs/Public/Shared Music/
Diskdoctor
Postby Aquarius » 08 Feb 2016, 11:11
I also had issues with NFS when setting up Rune/Volumio/Moode etc..
Only Samba did the trick.
However, when chosing samba, go down to the "advanced" section and be sure to remove the options that may be hidden there. If I remember correctly, those are NFS options only and will be rejected by mount.cifs.
It solved my issues.
-- Aquarius
Aquarius
Postby silvrr » 08 Feb 2016, 15:23
How is the my book connected?
silvrr
