Hidden SSID and AP
Hidden SSID and AP
Postby aistaca » 05 Jun 2017, 14:09
Jimmy
aistaca
Re: Hidden SSID and AP
Postby hondagx35 » 06 Jun 2017, 10:27
Hi aistaca,
connecting to a network with hidden SSID seems to take more time.
The AP feature tests if there is an IP assigned to one of the nics.
- if yes, the AP is not started even if enabled
- if not, NETCTL is stopped and the AP is started.
You can try to insert a delay (sleep) before this line:
https://github.com/hondagx35/RuneUI/blo ... Y_wrk#L304
Postby aistaca » 08 Jun 2017, 11:13
Thank you for the reply. Unfortunately, I have switched back to build 20160321 as the latest image somehow give very poor response and latency on the webserver side. I may try your solution later when I reflash my card.
While on it, is there a way to fix the replaygain (track and auto mode) and dirble (null) issue without reflashing to the 20170209 build? Or would it be better to use latest build and give you the debug info?
Jimmy
Jimmy
aistaca
Postby hondagx35 » 10 Jun 2017, 13:56
Postby aistaca » 10 Jun 2017, 15:09
Thank you for the reply. This may seems like a dumb question but.. how do I apply the fix?
Do I have to clone the entire git and recompile? Do I do it from master or dev, or get the code from master and modify according to the fix you point at?
Jimmy
Jimmy
aistaca
Postby hondagx35 » 10 Jun 2017, 15:15
Postby aistaca » 10 Jun 2017, 16:02
Thank you for the time and the guide. I am familiar with SSH, never though the sources would be in /var/www directory.
Dirble seems to response better now, although the UI still shows as Dirble (null). It won't load some radios (nonstop loading trying to open radio list), but probably because I'm inside China at the moment (blame the great firewall of China). The order of code on mine was slightly different from yours (not in similar line number), maybe I should copy your entire code and replace mine?
Replaygain works as it should (or maybe?), I couldn't hear the difference on a few songs, maybe just missing tags.
Best regards,
Jimmy
Jimmy
aistaca
Postby aistaca » 13 Jun 2017, 08:47
I got a new SD card today and able to test your solution on hidden SSID problem. I can confirm that adding sleep(100) does fix the wifi check problem. (now hidden SSID is detected)
Another problem I discovered was regarding the latency issue on the UI I had before. I'm very sure now that runeUI frozen up whenever it tried to load artist information and album cover. When all information are loaded the UI operates normally.
I really like the info panel by the way, it's very cool. However, as I am in China now, connection to outside world is very slow and this makes the latest update unusable for me. Just a suggestion: maybe an option to turn this feature off, maybe saved all information locally, or just general optimization on the UI and info panel (maybe running on separate thread?)
Anyway, thanks for your time Frank.
Best regards to the development of RuneAudio,
Jimmy
Jimmy
aistaca
Postby hondagx35 » 13 Jun 2017, 12:07
Postby aistaca » 13 Jun 2017, 13:40
Frank, you are awesome!
Thank you for the help, it is much responsive now. I tried to turn on and off each of them, it does seems that both are affecting the UI response.
Jimmy
Jimmy
aistaca
