HiFi Berry DAC support
Re: HiFi Berry DAC support
Postby bower » 21 Sep 2014, 17:26
Thank you for your answer, I will wait for the next version. In the meantime I also can use the USB input of my DAC. I just wanted get some information before I order the HifiBerry Digi+. My DAC does not receive 24/96 signal on the USB input.
bower
Postby bower » 12 Oct 2014, 10:02
I've read from ACX (thanks for the answer and your work), that the new version will work with HifiBerry+ (DAC/Digi) out-of-the box, but though I don't know anything about it's release date, I would like to ask if:
Anyone managed to make Hifiberry+ work with of course PI model B+?
On HifiBerry site it is written that kernel upgrade solves the problem, but I think not. (http://www.hifiberry.com/guides/supportedsoftware/)
I've also tried module setup described here: http://www.hifiberry.com/guides/hifiber ... iguration/ with no luck.
When I'm trying to use Digi+ and starting to play, the complete USB subsystem stops working including the ethernet connector. This problem seems to come after pri-update.
Can anyone tell me some guidelines about the change?
- I guess, that model B+/Digi+ differs from the original just in the pinout.
- Where do I have to follow this change? In the kernel module? rpi-update does not solve this?
- Maybe the new kernel is needed for the PI model B+, and also a new module that handles HifiBerry Digi+?
Thanks for any information, that helps.
bower
Postby gdp65 » 29 Jan 2015, 15:29
hi
I downloaded the latest version 0.3 beta and it still doesn't work with the hifiberry Digi +. Am I doing something wrong or is there still work being done on this?
gdp65
Postby ACX » 01 Feb 2015, 02:11
Previous
Users browsing this forum: Bing [Bot] and 1 guest
