HifiBerry Amp+ on Raspberry Pi 2 with hardware volume
Postby hondagx35 » 15 Jun 2015, 21:57
Re: HifiBerry Amp+ on Raspberry Pi 2 with hardware volume
Postby dagsix » 17 Jun 2015, 18:50
1. "enabled -hardware" works! However the volume has to be set above 50 to hear anything and close to 70 for normal play...
Before the "enabled-software" setting volume would be around 35 for normal play.
Is this expected?
2. The UI for the song time elapsed is really inaccurate now. It seems like it isn't refreshing the time elapsed. If I pause a track mid way through playing the elapsed time UI will 'jump' to the correct position. Update: this is strangely intermittent
3. Also, it seems like the sound is clearer. :D
4. Very noticeable delay between clicking on UI and response.
dagsix
