Hifiberry amp
Hifiberry amp
Postby karlmorten » 28 Dec 2014, 00:24
I don't manage to get sound from the hifiberry amp. See debug below. Any suggestions?
###### System info ######
Linux version 3.12.26-1-ARCH (nobody@root-armv6-copy) (gcc version 4.8.2 20131219 (prerelease) (GCC) ) #1 PREEMPT Fri Aug 8 17:40:14 MDT 2014
system time: Sat Dec 27 23:54:42 CET 2014
system load: 0.06 0.20 0.11 2/79 668
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
###### System load statistics (procinfo -H) ######
Memory: Total Used Free Buffers
RAM: 482.42MiB 97.08MiB 385.34MiB 9.02MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Sat Dec 27 23:50:53 2014 Load average: 0.06 0.20 0.11 2/81 670
user : 00:00:16.14 7.1% page in : 58364
nice : 00:00:03.43 1.5% page out: 1556
system: 00:00:13.08 5.8% page act: 5334
IOwait: 00:00:00.59 0.3% page dea: 0
hw irq: 00:00:00.28 0.1% page flt: 228908
sw irq: 00:00:00.40 0.2% swap in : 0
idle : 00:03:12.43 85.0% swap out: 0
uptime: 00:03:48.57 context : 40801
irq 3: 11986 irq 66: 1
irq 16: 0 irq 75: 1
irq 20: 0 irq 77: 7660
irq 32: 67166 irq 79: 0
irq 52: 0 irq 80: 0
irq 65: 7 irq 84: 10171
mmcblk0 1765r 1 mmcblk0p2 2r
mmcblk0p1 88r mmcblk0p5 1616r
eth0 TX 214.50KiB RX 61.45KiB ifb1 TX 0.00B RX 0.00B
ifb0 TX 0.00B RX 0.00B lo TX 394.04KiB RX 394.04KiB
###### Active processes (pstree) ######
systemd-+-agetty
|-avahi-daemon---avahi-daemon
|-avahi-dnsconfd
|-dbus-daemon
|-devmon---udevil
|-dhcpcd
|-ifplugd
|-mpd---5*[{mpd}]
|-nginx---nginx
|-php-fpm---3*[php-fpm]
|-redis-server---2*[{redis-server}]
|-rpcbind
|-rune_PL_wrk
|-rune_SY_wrk---sh---debug_collector---sh---pstree
|-shairport---{shairport}
|-sshd
`-systemd-udevd
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k3.12.26-1-ARCH.
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [sndrpihifiberry]: snd_rpi_hifiber - snd_rpi_hifiberry_dac
PLAYBACK devices: (aplay -l)
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 []
Subdevices: 1/1
PCM devices: (aplay -L)
null
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_dac,
sysdefault:CARD=sndrpihifiberry
card 0:
Simple mixer control 'PCM',0
card 1:
no mixer scontrols
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=2,iface=MIXER,name='PCM Playback Switch'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
card 1:
no mixer controls
Output 1 (snd_rpi_hifiberry_dac) is enabled
Output 2 (bcm2835 ALSA) is enabled
###### mpd.conf ######
zeroconf_enabled "yes"
zeroconf_name "RuneAudio"
bind_to_address "/run/mpd.sock"
bind_to_address "any"
port "6600"
max_connections "20"
user "mpd"
group "audio"
db_file "/var/lib/mpd/mpd.db"
sticker_file "/var/lib/mpd/sticker.sql"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
auto_update "no"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
volume_normalization "no"
audio_buffer_size "2048"
buffer_before_play "10%"
gapless_mp3_playback "yes"
audio_output {
name "snd_rpi_hifiberry_dac"
type "alsa"
device "hw:1,0"
mixer_type "hardware"
mixer_device "hw:hw:1,0"
mixer_control ",0"
mixer_index "0"
dsd_usb "yes"
auto_resample "no"
auto_format "no"
enabled "yes"
audio_output {
name "bcm2835 ALSA"
type "alsa"
device "hw:0,0"
mixer_device "hw:hw:0,0"
mixer_control ",0"
mixer_index "0"
dsd_usb "yes"
auto_resample "no"
auto_format "no"
hardware platform: RaspberryPi
current orionprofile: RuneAudio
kernel scheduler for mmcblk0: [noop] deadline cfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 1500000
/proc/sys/kernel/sched_rt_period_us: 1000000
/proc/sys/kernel/sched_rt_runtime_us: 950000
/proc/sys/kernel/sched_autogroup_enabled: 1
/proc/sys/kernel/sched_rr_timeslice_ms: 10
/proc/sys/kernel/sched_min_granularity_ns: 750000
/proc/sys/kernel/sched_wakeup_granularity_ns: 1000000
Module = "snd_usb_audio"
Attributes:
coresize = "117624"
initsize = "0"
initstate = "live"
refcnt = "0"
srcversion = "130402A40F6833AC96ED23B"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "-1,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf20bf74"
.ARM.exidx.init.text= "0xbf20bf6c"
.ARM.exidx = "0xbf20e688"
.ARM.extab = "0xbf20e658"
.ARM.extab.init.text= "0xbf20bf60"
.bss = "0xbf211734"
.data = "0xbf20ebdc"
.exit.text = "0xbf2095b0"
.gnu.linkonce.this_module= "0xbf2115c0"
.init.text = "0xbf21a000"
.note.gnu.build-id = "0xbf20ebb8"
.rodata = "0xbf2095c0"
.rodata.str1.4 = "0xbf20bf7c"
.strtab = "0xbf21f378"
.symtab = "0xbf21a048"
.text = "0xbf1fc000"
__param = "0xbf20e5c8"
###### Systemd active startup scripts (ls -lah /etc/systemd/system/multi-user.target.wants/) ######
total 8.0K
drwxr-xr-x 2 root root 4.0K Sep 27 10:51 .
drwxr-xr-x 6 root root 4.0K Aug 31 20:18 ..
lrwxrwxrwx 1 root root 46 Aug 13 2013 avahi-dnsconfd.service -> /usr/lib/systemd/system/avahi-dnsconfd.service
lrwxrwxrwx 1 root root 47 Aug 10 18:45 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 37 Aug 9 16:34 nginx.service -> /usr/lib/systemd/system/nginx.service
lrwxrwxrwx 1 root root 39 Aug 9 16:33 php-fpm.service -> /usr/lib/systemd/system/php-fpm.service
lrwxrwxrwx 1 root root 37 Jul 18 23:18 redis.service -> /usr/lib/systemd/system/redis.service
lrwxrwxrwx 1 root root 51 Sep 3 02:59 remote-fs.target -> ../../../../usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 43 Aug 9 16:36 rune_PL_wrk.service -> /usr/lib/systemd/system/rune_PL_wrk.service
lrwxrwxrwx 1 root root 43 Aug 10 17:40 rune_SY_wrk.service -> /usr/lib/systemd/system/rune_SY_wrk.service
lrwxrwxrwx 1 root root 36 Aug 13 2013 sshd.service -> /usr/lib/systemd/system/sshd.service
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,noatime,nodiratime,nouser_xattr,errors=remount-ro,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=242780k,nr_inodes=60695,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_prio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=22,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
logs /var/log ramfs rw,nosuid,nodev,noatime,mode=1777,size=1M 0 0
rune-logs /var/log/runeaudio ramfs rw,nosuid,nodev,noatime,mode=1777,size=10M 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
###### Filesystem mounts - free space (df -h) ######
/dev/root 1.7G 698M 842M 46% /
devtmpfs 238M 0 238M 0% /dev
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 242M 276K 241M 1% /run
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 242M 4.0K 242M 1% /tmp
/dev/mmcblk0p1 90M 43M 48M 47% /boot
###### Loaded kernel modules ######
Module Size Used by
ecb 1891 0
md4 3351 0
nls_utf8 1259 0
cifs 442790 0
snd_usb_audio 117624 0
snd_usbmidi_lib 19191 1 snd_usb_audio
snd_hwdep 5977 1 snd_usb_audio
snd_rawmidi 21562 1 snd_usbmidi_lib
snd_seq_device 6493 1 snd_rawmidi
snd_soc_hifiberry_dac 2115 0
snd_soc_pcm5102a 1414 1
cfg80211 440129 0
snd_soc_wm8804 7940 0
snd_soc_bcm2708_i2s 6202 2
regmap_mmio 2838 1 snd_soc_bcm2708_i2s
snd_soc_core 155972 4 snd_soc_wm8804,snd_soc_hifiberry_dac,snd_soc_pcm5102a,snd_soc_bcm2708_i2s
leds_gpio 2142 0
led_class 4162 1 leds_gpio
snd_compress 8351 1 snd_soc_core
snd_pcm_dmaengine 5533 1 snd_soc_core
regmap_spi 1941 2 snd_soc_wm8804,snd_soc_core
bcm2708_dmaengine 5224 1
spi_bcm2708 4844 0
virt_dma 2309 1 bcm2708_dmaengine
regmap_i2c 1685 2 snd_soc_wm8804,snd_soc_core
i2c_bcm2708 4895 0
snd_bcm2835 19609 0
snd_pcm 81802 5 snd_bcm2835,snd_usb_audio,snd_soc_core,snd_soc_hifiberry_dac,snd_pcm_dmaengine
snd_page_alloc 5192 1 snd_pcm
snd_timer 20370 1 snd_pcm
snd 62046 10 snd_bcm2835,snd_usb_audio,snd_soc_core,snd_hwdep,snd_timer,snd_pcm,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_compress
bcm2708_rng 1044 0
rng_core 4159 1 bcm2708_rng
ipv6 319689 0
###### Network listening sockets (netstat -lnp) ######
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 650/mpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 397/shairport
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 118/redis-server 12
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 139/rpcbind
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 140/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 140/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 140/nginx: master p
tcp 0 0 0.0.0.0:83 0.0.0.0:* LISTEN 140/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 117/sshd
udp 0 0 0.0.0.0:736 0.0.0.0:* 139/rpcbind
udp 0 0 0.0.0.0:5353 0.0.0.0:* 130/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 338/dhcpcd
udp 0 0 0.0.0.0:58708 0.0.0.0:* 130/avahi-daemon: r
udp 0 0 0.0.0.0:111 0.0.0.0:* 139/rpcbind
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] STREAM LISTENING 8299 451/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 10863 650/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 8302 451/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 4463 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 8305 451/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 4467 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 4480 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 5249 139/rpcbind /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 3006 1/init /run/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 3021 1/init /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 4821 118/redis-server 12 /tmp/redis.sock
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:51989 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51937 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51958 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51933 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51948 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51917 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51955 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51931 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51964 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51920 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51976 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51914 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51986 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51966 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51972 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51924 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51950 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51983 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51957 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.117:80 192.168.1.130:58649 TIME_WAIT -
tcp 0 0 127.0.0.1:51977 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51936 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51905 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51926 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51975 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51988 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51947 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51919 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51944 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51952 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51940 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51916 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51946 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51949 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51907 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:58506 TIME_WAIT -
tcp 0 0 192.168.1.117:59578 78.46.19.144:80 TIME_WAIT -
tcp 0 0 127.0.0.1:51915 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51985 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51899 127.0.0.1:6379 TIME_WAIT -
tcp 90 355 192.168.1.117:80 192.168.1.142:56260 ESTABLISHED 141/nginx: worker p
tcp 0 0 127.0.0.1:51918 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51922 127.0.0.1:6379 TIME_WAIT -
tcp 78 0 192.168.1.117:80 192.168.1.142:56262 ESTABLISHED 141/nginx: worker p
tcp 0 0 127.0.0.1:51921 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51898 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51906 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51954 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51941 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.117:80 192.168.1.130:58651 ESTABLISHED 141/nginx: worker p
tcp 0 0 127.0.0.1:51982 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51973 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.117:80 192.168.1.130:58647 TIME_WAIT -
tcp 0 0 127.0.0.1:51981 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51925 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51927 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:82 127.0.0.1:34372 TIME_WAIT -
tcp 0 0 127.0.0.1:51967 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51903 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51908 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51900 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51980 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51963 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51971 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51942 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51934 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:58497 TIME_WAIT -
tcp 0 0 192.168.1.117:80 192.168.1.130:58650 ESTABLISHED 141/nginx: worker p
tcp 0 0 192.168.1.117:80 192.168.1.130:58652 TIME_WAIT -
tcp 0 0 127.0.0.1:51962 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51938 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51909 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.117:80 192.168.1.130:58648 TIME_WAIT -
tcp 0 0 127.0.0.1:51965 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:58432 TIME_WAIT -
tcp 0 0 127.0.0.1:51935 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51974 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51901 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51943 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51923 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51987 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51929 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51932 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51912 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51939 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51928 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51979 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51930 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:37652 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:58439 TIME_WAIT -
tcp 0 0 127.0.0.1:51913 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51970 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51951 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51984 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51910 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:82 127.0.0.1:34431 TIME_WAIT -
tcp 0 0 127.0.0.1:51945 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:51959 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.117:59519 78.46.19.144:80 TIME_WAIT -
Active UNIX domain sockets (w/o servers)
unix 2 [ ] DGRAM 3004 1/init /run/systemd/notify
unix 2 [ ] DGRAM 3024 1/init /run/systemd/shutdownd
unix 3 [ ] DGRAM 3820 89/systemd-udevd
unix 3 [ ] STREAM CONNECTED 5067 1/init
unix 3 [ ] STREAM CONNECTED 5132 134/dbus-daemon
unix 3 [ ] STREAM CONNECTED 7958 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 12386 120/php
unix 3 [ ] DGRAM 3819 89/systemd-udevd
unix 3 [ ] STREAM CONNECTED 5133 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 5131 134/dbus-daemon
unix 3 [ ] STREAM CONNECTED 5337 140/nginx: master p
unix 3 [ ] STREAM CONNECTED 5098 135/avahi-daemon: c
unix 3 [ ] STREAM CONNECTED 5336 140/nginx: master p
unix 3 [ ] STREAM CONNECTED 12391 650/mpd /run/mpd.sock
unix 3 [ ] STREAM CONNECTED 8297 451/php-fpm: master
unix 3 [ ] STREAM CONNECTED 8298 451/php-fpm: master
unix 3 [ ] STREAM CONNECTED 12381 118/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 5334 140/nginx: master p
unix 3 [ ] STREAM CONNECTED 12030 118/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 12046 662/php
unix 3 [ ] STREAM CONNECTED 5161 130/avahi-daemon: r /var/run/avahi-daemon/socket
unix 3 [ ] STREAM CONNECTED 7957 397/shairport
unix 3 [ ] STREAM CONNECTED 5108 130/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 5134 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 10867 650/mpd
unix 3 [ ] STREAM CONNECTED 4869 125/avahi-dnsconfd
unix 3 [ ] STREAM CONNECTED 5097 130/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 12029 147/php
unix 3 [ ] STREAM CONNECTED 12380 120/php
unix 3 [ ] STREAM CONNECTED 12048 118/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 10868 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 5335 140/nginx: master p
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: ifb0: mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether ce:a1:99:f0:db:15 brd ff:ff:ff:ff:ff:ff
3: ifb1: mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether 46:32:45:6a:f3:67 brd ff:ff:ff:ff:ff:ff
4: eth0: mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:b1:7f:ff brd ff:ff:ff:ff:ff:ff
inet 192.168.1.117/24 brd 192.168.1.255 scope global eth0
###### Network interfaces (ifconfig) ######
eth0: flags=4163 mtu 1500
inet 192.168.1.117 netmask 255.255.255.0 broadcast 192.168.1.255
ether b8:27:eb:b1:7f:ff txqueuelen 1000 (Ethernet)
RX packets 645 bytes 68103 (66.5 KiB)
RX errors 0 dropped 5 overruns 0 frame 0
TX packets 586 bytes 322899 (315.3 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 0 (Local Loopback)
RX packets 7590 bytes 435095 (424.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 7590 bytes 435095 (424.8 KiB)
###### Network netctl profiles (netctl list) ######
eth0
eth0 netctl status
netctl@eth0.service - Networking for netctl profile eth0
Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static)
Active: inactive (dead)
Docs: man:netctl.profile(5)
eth0 netctl profile
Description='eth0 connection'
Interface=eth0
ForceConnect=yes
SkipNoCarrier=yes
Connection=ethernet
IP=dhcp
ExecUpPost='/usr/bin/ntpd -gq || true'
###### Network wifi status (iwconfig) ######
lo no wireless extensions.
eth0 no wireless extensions.
ifb0 no wireless extensions.
ifb1 no wireless extensions.
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.26-1-ARCH (nobody@root-armv6-copy) (gcc version 4.8.2 20131219 (prerelease) (GCC) ) #1 PREEMPT Fri Aug 8 17:40:14 MDT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1e800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat c089bdf4, node_mem_map c097b000
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125984
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0x91b17fff smsc95xx.macaddr=B8:27:EB:B1:7F:FF sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000 ipv6.disable=1 avoid_safe_mode=1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 console=tty1 root=/dev/mmcblk0p5 rootfstype=ext4 elevator=noop apparmor=0 security="" rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 485564K/507904K available (6133K kernel code, 334K rwdata, 2096K rodata, 245K init, 858K bss, 22340K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xdf800000 - 0xff000000 ( 504 MB)
lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0811598 (8230 kB)
.init : 0xc0812000 - 0xc084f59c ( 246 kB)
.data : 0xc0850000 - 0xc08a39ac ( 335 kB)
.bss : 0xc08a39ac - 0xc097a2f0 ( 859 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000632] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.000657] pid_max: default: 32768 minimum: 301
[ 0.001157] Mount-cache hash table entries: 512
[ 0.002012] Initializing cgroup subsys memory
[ 0.002093] Initializing cgroup subsys devices
[ 0.002114] Initializing cgroup subsys freezer
[ 0.002131] Initializing cgroup subsys blkio
[ 0.002145] Initializing cgroup subsys perf_event
[ 0.002180] Initializing cgroup subsys net_prio
[ 0.002316] CPU: Testing write buffer coherency: ok
[ 0.002782] Setting up static identity map for 0xc05d7458 - 0xc05d74b4
[ 0.005050] devtmpfs: initialized
[ 0.022510] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.023845] xor: measuring software checksum speed
[ 0.120347] arm4regs : 974.000 MB/sec
[ 0.220403] 8regs : 470.800 MB/sec
[ 0.320509] 32regs : 470.800 MB/sec
[ 0.320529] xor: using function: arm4regs (974.000 MB/sec)
[ 0.321784] NET: Registered protocol family 16
[ 0.327530] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.328189] cpuidle: using governor ladder
[ 0.328212] cpuidle: using governor menu
[ 0.329023] bcm2708.uart_clock = 0
[ 0.331163] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.331184] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.331201] mailbox: Broadcom VideoCore Mailbox driver
[ 0.331283] bcm2708_vcio: mailbox at f200b880
[ 0.331377] bcm_power: Broadcom power driver
[ 0.331398] bcm_power_open() -> 0
[ 0.331410] bcm_power_request(0, 8)
[ 0.832123] bcm_mailbox_read -> 00000080, 0
[ 0.832143] bcm_power_request -> 0
[ 0.832390] Serial: AMBA PL011 UART driver
[ 0.832522] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.858881] bio: create slab at 0
[ 1.022375] raid6: int32x1 46 MB/s
[ 1.192388] raid6: int32x2 71 MB/s
[ 1.362583] raid6: int32x4 91 MB/s
[ 1.532715] raid6: int32x8 99 MB/s
[ 1.532737] raid6: using algorithm int32x8 (99 MB/s)
[ 1.532751] raid6: using intx1 recovery algorithm
[ 1.533384] SCSI subsystem initialized
[ 1.533735] usbcore: registered new interface driver usbfs
[ 1.533850] usbcore: registered new interface driver hub
[ 1.534144] usbcore: registered new device driver usb
[ 1.536947] Switched to clocksource stc
[ 1.561841] FS-Cache: Loaded
[ 1.562149] CacheFiles: Loaded
[ 1.576404] NET: Registered protocol family 2
[ 1.577654] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.577796] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.577899] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.577986] TCP: reno registered
[ 1.578013] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.578048] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.578518] NET: Registered protocol family 1
[ 1.579171] RPC: Registered named UNIX socket transport module.
[ 1.579197] RPC: Registered udp transport module.
[ 1.579210] RPC: Registered tcp transport module.
[ 1.579222] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.581143] bcm2708_dma: DMA manager at f2007000
[ 1.581281] bcm2708_gpio: bcm2708_gpio_probe c085e470
[ 1.581769] vc-mem: phys_addr:0x00000000 mem_base=0x1fa00000 mem_size:0x20000000(512 MiB)
[ 1.792270] VFS: Disk quotas dquot_6.5.2
[ 1.792606] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.794803] FS-Cache: Netfs 'nfs' registered for caching
[ 1.795870] NFS: Registering the id_resolver key type
[ 1.795983] Key type id_resolver registered
[ 1.796002] Key type id_legacy registered
[ 1.797678] bio: create slab at 1
[ 1.799216] Btrfs loaded
[ 1.800334] aufs 3.12.x-20140804
[ 1.800390] msgmni has been set to 964
[ 1.802747] async_tx: api initialized (async)
[ 1.803119] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.803464] io scheduler noop registered (default)
[ 1.803489] io scheduler deadline registered
[ 1.803792] io scheduler cfq registered
[ 1.805156] BCM2708FB: allocated DMA memory 5ec00000
[ 1.805225] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.809373] Console: switching to colour frame buffer device 82x26
[ 1.811869] uart-pl011 dev:f1: no DMA platform data
[ 1.812536] vc-cma: Videocore CMA driver
[ 1.812557] vc-cma: vc_cma_base = 0x00000000
[ 1.812570] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.812582] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.822768] brd: module loaded
[ 1.828521] loop: module loaded
[ 1.828822] vchiq: vchiq_init_state: slot_zero = 0xde800000, is_master = 0
[ 1.829759] Loading iSCSI transport class v2.0-870.
[ 1.832549] usbcore: registered new interface driver ax88179_178a
[ 1.832702] usbcore: registered new interface driver smsc95xx
[ 1.832909] usbcore: registered new interface driver cdc_ncm
[ 1.832936] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.033273] Core Release: 2.80a
[ 2.033307] Setting default values for core params
[ 2.033352] Finished setting default values for core params
[ 2.233407] Using Buffer DMA mode
[ 2.233433] Periodic Transfer Interrupt Enhancement - disabled
[ 2.233446] Multiprocessor Interrupt Enhancement - disabled
[ 2.233461] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.233479] Dedicated Tx FIFOs mode
[ 2.233864] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdec14000 dma = 0x5ec14000 len=9024
[ 2.233903] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
[ 2.233930] dwc_otg: Microframe scheduler enabled
[ 2.233991] WARN::hcd_init:473: FIQ at 0xc04590d8
[ 2.234012] WARN::hcd_init:474: FIQ ASM at 0xc045938c length 36
[ 2.234044] WARN::hcd_init:500: MPHI regs_base at 0xdf806000
[ 2.234077] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.234132] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.234228] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.234270] Init: Port Power? op_state=1
[ 2.234282] Init: Power Port (0)
[ 2.234624] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.234651] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.234670] usb usb1: Product: DWC OTG Controller
[ 2.234689] usb usb1: Manufacturer: Linux 3.12.26-1-ARCH dwc_otg_hcd
[ 2.234706] usb usb1: SerialNumber: bcm2708_usb
[ 2.235562] hub 1-0:1.0: USB hub found
[ 2.235655] hub 1-0:1.0: 1 port detected
[ 2.236144] dwc_otg: FIQ enabled
[ 2.236163] dwc_otg: NAK holdoff enabled
[ 2.236176] dwc_otg: FIQ split-transaction FSM enabled
[ 2.236198] Module dwc_common_port init
[ 2.236667] usbcore: registered new interface driver usb-storage
[ 2.237099] mousedev: PS/2 mouse device common for all mice
[ 2.237580] md: linear personality registered for level -1
[ 2.237602] md: raid0 personality registered for level 0
[ 2.237616] md: raid1 personality registered for level 1
[ 2.237628] md: raid10 personality registered for level 10
[ 2.237993] md: raid6 personality registered for level 6
[ 2.238014] md: raid5 personality registered for level 5
[ 2.238028] md: raid4 personality registered for level 4
[ 2.238042] md: multipath personality registered for level -4
[ 2.238054] md: faulty personality registered for level -5
[ 2.238524] device-mapper: uevent: version 1.0.3
[ 2.239060] device-mapper: ioctl: 4.26.0-ioctl (2013-08-15) initialised: dm-devel@redhat.com
[ 2.239943] device-mapper: multipath: version 1.6.0 loaded
[ 2.239973] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 2.239991] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 2.240006] device-mapper: multipath service-time: version 0.2.0 loaded
[ 2.240026] device-mapper: raid: Loading target version 1.5.2
[ 2.240276] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.240384] bcm2835-cpufreq: switching to governor ondemand
[ 2.240401] bcm2835-cpufreq: switching to governor ondemand
[ 2.240581] sdhci: Secure Digital Host Controller Interface driver
[ 2.240599] sdhci: Copyright(c) Pierre Ossman
[ 2.240694] sdhci: Enable low-latency mode
[ 2.277004] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.277270] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.277376] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.277400] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.277564] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.278091] usbcore: registered new interface driver usbhid
[ 2.278112] usbhid: USB HID core driver
[ 2.278900] zram: Created 1 device(s) ...
[ 2.279478] TCP: cubic registered
[ 2.279505] Initializing XFRM netlink socket
[ 2.279549] NET: Registered protocol family 17
[ 2.279744] Key type dns_resolver registered
[ 2.287839] registered taskstats version 1
[ 2.294212] md: Waiting for all devices to be available before autodetect
[ 2.294238] md: If you don't use raid, use raid=noautodetect
[ 2.299588] md: Autodetecting RAID arrays.
[ 2.299619] md: Scanned 0 and added 0 devices.
[ 2.301739] md: autorun ...
[ 2.301758] md: ... autorun DONE.
[ 2.302170] Waiting for root device /dev/mmcblk0p5...
[ 2.427162] Indeed it is in host mode hprt0 = 00021501
[ 2.498617] mmc0: could read SD Configuration register (SCR) at the 2th attempt
[ 2.509947] mmc0: read SD Status register (SSR) after 2 attempts
[ 2.516388] mmc0: new high speed SDHC card at address e624
[ 2.517320] mmcblk0: mmc0:e624 SE08G 7.40 GiB
[ 2.519562] mmcblk0: p1 p2 < p5 >
[ 2.607105] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.607306] Indeed it is in host mode hprt0 = 00001101
[ 2.807436] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.807492] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.808487] hub 1-1:1.0: USB hub found
[ 2.808635] hub 1-1:1.0: 5 ports detected
[ 2.822918] EXT4-fs (mmcblk0p5): recovery complete
[ 2.824301] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.824422] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 2.833947] devtmpfs: mounted
[ 2.834818] Freeing unused kernel memory: 244K (c0812000 - c084f000)
[ 3.087308] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.171236] systemd[1]: systemd 216 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID -ELFUTILS +KMOD -IDN )
[ 3.171998] systemd[1]: Detected architecture 'arm'.
[ 3.187554] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.187591] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.190713] smsc95xx v1.0.4
[ 3.253010] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b1:7f:ff
[ 3.308164] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 3.308357] systemd[1]: Inserted module 'ipv6'
[ 3.311096] systemd[1]: Set hostname to .
[ 3.902152] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.913241] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.914190] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.914537] systemd[1]: Expecting device sys-subsystem-net-devices-eth0.device...
[ 3.915440] systemd[1]: Starting Remote File Systems.
[ 3.916279] systemd[1]: Reached target Remote File Systems.
[ 3.916745] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 3.917621] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.917931] systemd[1]: Starting Paths.
[ 3.918756] systemd[1]: Reached target Paths.
[ 3.919084] systemd[1]: Starting Encrypted Volumes.
[ 3.919906] systemd[1]: Reached target Encrypted Volumes.
[ 3.920431] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.922228] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.922625] systemd[1]: Starting Swap.
[ 3.923436] systemd[1]: Reached target Swap.
[ 3.923763] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.924560] systemd[1]: Starting Root Slice.
[ 3.993606] systemd[1]: Created slice Root Slice.
[ 3.993961] systemd[1]: Starting Device-mapper event daemon FIFOs.
[ 3.995236] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.995662] systemd[1]: Starting udev Control Socket.
[ 3.996906] systemd[1]: Listening on udev Control Socket.
[ 3.997563] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.997653] systemd[1]: Socket service systemd-journald.service not loaded, refusing.
[ 3.999170] systemd[1]: Failed to listen on Journal Socket (/dev/log).
[ 3.999571] systemd[1]: Starting Delayed Shutdown Socket.
[ 4.000711] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.001143] systemd[1]: Starting udev Kernel Socket.
[ 4.002267] systemd[1]: Listening on udev Kernel Socket.
[ 4.002617] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 4.005270] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.005675] systemd[1]: Starting Journal Socket.
[ 4.005760] systemd[1]: Socket service systemd-journald.service not loaded, refusing.
[ 4.013076] systemd[1]: Failed to listen on Journal Socket.
[ 4.015099] systemd[1]: Starting System Slice.
[ 4.020122] systemd[1]: Created slice System Slice.
[ 4.020648] systemd[1]: Started File System Check on Root Device.
[ 4.021029] systemd[1]: Mounting Temporary Directory...
[ 4.029377] systemd[1]: Starting system-netctl\x2difplugd.slice.
[ 4.041419] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 4.042032] systemd[1]: Starting system-getty.slice.
[ 4.047710] systemd[1]: Created slice system-getty.slice.
[ 4.075867] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.076241] systemd[1]: Starting udev Coldplug all Devices...
[ 4.113691] systemd[1]: Starting Load Kernel Modules...
[ 4.131724] systemd[1]: Mounted Huge Pages File System.
[ 4.132161] systemd[1]: Starting Setup Virtual Console...
[ 4.169843] systemd[1]: Mounting Debug File System...
[ 4.215041] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.222074] systemd-modules-load[64]: Module 'nfs' is builtin
[ 4.246618] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.256744] bcm2708_rng_init=df80a000
[ 4.267389] systemd-modules-load[64]: Inserted module 'bcm2708_rng'
[ 4.351424] systemd[1]: Starting Slices.
[ 4.373178] systemd[1]: Reached target Slices.
[ 4.373673] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.381940] systemd-modules-load[64]: Inserted module 'snd_bcm2835'
[ 4.444003] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.448281] systemd[1]: Mounted Debug File System.
[ 4.457655] systemd[1]: Mounted Temporary Directory.
[ 4.480579] systemd[1]: Started Load Kernel Modules.
[ 4.497277] systemd[1]: Started Setup Virtual Console.
[ 4.505143] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.647254] EXT4-fs (mmcblk0p5): Mount option "nouser_xattr" will be removed by 3.5
Contact linux-ext4@vger.kernel.org if you think we should keep it.
[ 4.647328] EXT4-fs (mmcblk0p5): re-mounted. Opts: nouser_xattr,errors=remount-ro
[ 4.707816] systemd[1]: Started Remount Root and Kernel File Systems.
[ 4.800458] systemd[1]: Started udev Coldplug all Devices.
[ 5.287912] systemd[1]: Started Rebuild Dynamic Linker Cache.
[ 5.288334] systemd[1]: Started Rebuild Hardware Database.
[ 5.288593] systemd[1]: Starting Load/Save Random Seed...
[ 5.296921] systemd[1]: Started Create System Users.
[ 5.304238] systemd[1]: Started First Boot Wizard.
[ 5.305252] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.333160] systemd[1]: Mounted FUSE Control File System.
[ 5.334340] systemd[1]: Mounting Configuration File System...
[ 5.346674] systemd[1]: Starting Apply Kernel Variables...
[ 5.482974] systemd[1]: Mounted Configuration File System.
[ 5.507314] systemd[1]: Started Load/Save Random Seed.
[ 5.514770] systemd[1]: Started Create Static Device Nodes in /dev.
[ 5.521317] systemd[1]: Started Apply Kernel Variables.
[ 5.791450] systemd[1]: Starting udev Kernel Device Manager...
[ 5.799950] systemd[1]: Starting Local File Systems (Pre).
[ 5.807287] systemd[1]: Reached target Local File Systems (Pre).
[ 5.807802] systemd[1]: Mounting /var/log...
[ 5.817306] systemd[1]: var-log.mount: Directory /var/log to mount over is not empty, mounting anyway.
[ 5.856526] systemd-udevd[89]: starting version 216
[ 5.887502] systemd[1]: Mounted /var/log.
[ 5.901189] systemd[1]: Started udev Kernel Device Manager.
[ 6.026071] systemd[1]: Mounting /var/log/runeaudio...
[ 6.088553] systemd[1]: Mounted /var/log/runeaudio.
[ 6.539848] bcm2708_i2c_init_pinmode(0,0)
[ 6.539878] bcm2708_i2c_init_pinmode(0,1)
[ 6.540150] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[ 6.553022] bcm2708_i2c_init_pinmode(1,2)
[ 6.553053] bcm2708_i2c_init_pinmode(1,3)
[ 6.553677] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[ 6.578143] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 6.584967] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 6.937783] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 7.054451] systemd[1]: Found device /dev/mmcblk0p1.
[ 7.055146] systemd[1]: Mounting /boot...
[ 7.135884] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.146457] systemd[1]: Mounted /boot.
[ 7.149484] systemd[1]: Starting Local File Systems.
[ 7.165696] systemd[1]: Reached target Local File Systems.
[ 7.166282] systemd[1]: Started Rebuild Journal Catalog.
[ 7.166867] systemd[1]: Started Update is Completed.
[ 7.167338] systemd[1]: Starting Create Volatile Files and Directories...
[ 7.396726] systemd[1]: Started Create Volatile Files and Directories.
[ 7.480836] systemd[1]: Found device SMSC9512/9514 Fast Ethernet Adapter.
[ 7.535393] systemd[1]: Starting Update UTMP about System Boot/Shutdown...
[ 7.706738] systemd[1]: Started Update UTMP about System Boot/Shutdown.
[ 7.906431] systemd[1]: Starting System Initialization.
[ 7.916519] systemd[1]: Reached target System Initialization.
[ 7.917417] systemd[1]: Starting Daily verification of password and group files.
[ 7.920166] systemd[1]: Started Daily verification of password and group files.
[ 7.920512] systemd[1]: Starting Daily rotation of log files.
[ 7.921413] systemd[1]: Started Daily rotation of log files.
[ 7.921752] systemd[1]: Starting Avahi mDNS/DNS-SD Stack Activation Socket.
[ 7.932822] systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 7.933229] systemd[1]: Starting D-Bus System Message Bus Socket.
[ 7.935722] systemd[1]: Listening on D-Bus System Message Bus Socket.
[ 7.936109] systemd[1]: Starting Daily Cleanup of Temporary Directories.
[ 7.936408] systemd[1]: Started Daily Cleanup of Temporary Directories.
[ 7.936676] systemd[1]: Starting Timers.
[ 7.943362] systemd[1]: Reached target Timers.
[ 7.943875] systemd[1]: Started Manage Sound Card State (restore and store).
[ 7.944140] systemd[1]: Starting Restore Sound Card State...
[ 7.955914] systemd[1]: Starting RPCbind Server Activation Socket.
[ 7.975941] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.977389] systemd[1]: Starting Sockets.
[ 7.984907] systemd[1]: Reached target Sockets.
[ 7.985339] systemd[1]: Starting Basic System.
[ 7.991494] systemd[1]: Reached target Basic System.
[ 7.991934] systemd[1]: Starting A high performance web server and a reverse proxy server...
[ 8.038610] systemd[1]: Started SSH Key Generation.
[ 8.038961] systemd[1]: Starting OpenSSH Daemon...
[ 8.099652] systemd[1]: Started OpenSSH Daemon.
[ 8.100187] systemd[1]: Starting Advanced key-value store...
[ 8.199314] systemd[1]: Started Advanced key-value store.
[ 8.199934] systemd[1]: Starting RuneAudio Playback Worker After=network.target...
[ 8.279319] systemd[1]: Started RuneAudio Playback Worker After=network.target.
[ 8.284823] systemd[1]: Starting The PHP FastCGI Process Manager...
[ 8.348483] systemd[1]: Starting Avahi DNS Configuration Daemon...
[ 8.457347] systemd[1]: Started Avahi DNS Configuration Daemon.
[ 8.457909] systemd[1]: Starting Automatic wired network connection using netctl profiles...
[ 8.564171] systemd[1]: Started Automatic wired network connection using netctl profiles.
[ 8.567694] systemd[1]: Starting Permit User Sessions...
[ 8.630981] systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
[ 8.643794] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.683307] systemd[1]: Starting D-Bus System Message Bus...
[ 8.792576] systemd[1]: Started D-Bus System Message Bus.
[ 9.297376] systemd[1]: Started Avahi mDNS/DNS-SD Stack.
[ 9.298366] systemd[1]: Starting RPC bind service...
[ 9.419542] systemd[1]: Started Restore Sound Card State.
[ 9.502069] systemd[1]: Started Permit User Sessions.
[ 9.587286] systemd[1]: Started RPC bind service.
[ 9.831160] systemd[1]: Started A high performance web server and a reverse proxy server.
[ 10.041629] systemd[1]: Started The PHP FastCGI Process Manager.
[ 10.184434] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 10.828383] systemd[1]: Starting Getty on tty1...
[ 10.860659] systemd[1]: Started Getty on tty1.
[ 10.861283] systemd[1]: Starting Login Prompts.
[ 10.863513] systemd[1]: Reached target Login Prompts.
[ 10.863920] systemd[1]: Starting Multi-User System.
[ 10.887226] systemd[1]: Reached target Multi-User System.
[ 10.887679] systemd[1]: Starting RuneAudio System Worker...
[ 10.925350] systemd[1]: Started RuneAudio System Worker.
[ 10.925992] systemd[1]: Starting Graphical Interface.
[ 10.937305] systemd[1]: Reached target Graphical Interface.
[ 10.947519] systemd[1]: Startup finished in 3.095s (kernel) + 7.845s (userspace) = 10.940s.
[ 11.282057] systemd[1]: Starting Sound Card.
[ 11.282309] systemd[1]: Reached target Sound Card.
[ 12.317640] systemd[1]: Stopping The PHP FastCGI Process Manager...
[ 12.442502] systemd[1]: Stopped The PHP FastCGI Process Manager.
[ 12.651050] cfg80211: Calling CRDA to update world regulatory domain
[ 13.209258] systemd[1]: Starting Music Player Daemon...
[ 13.220849] systemd[1]: Started Music Player Daemon.
[ 14.645324] systemd[1]: mpd.service: main process exited, code=exited, status=1/FAILURE
[ 14.661246] systemd[1]: Unit mpd.service entered failed state.
[ 14.947486] systemd[1]: Starting Samba NetBIOS name server...
[ 14.954074] systemd[1]: Started Samba NetBIOS name server.
[ 15.600320] systemd[1]: Starting Samba NetBIOS name server...
[ 15.606659] systemd[1]: Started Samba NetBIOS name server.
[ 17.431735] snd-hifiberry-dac snd-hifiberry-dac.0: pcm5102a-hifi <-> bcm2708-i2s.0 mapping ok
[ 19.503922] systemd[1]: Stopped Music Player Daemon.
[ 20.605288] systemd[1]: Starting Music Player Daemon...
[ 20.611934] systemd[1]: Started Music Player Daemon.
[ 22.050286] systemd[1]: Started Music Player Daemon.
[ 23.274018] systemd[1]: Time has been changed
[ 24.419667] systemd[1]: Stopped Music Player Daemon.
[ 25.542765] systemd[1]: Starting Music Player Daemon...
[ 25.549267] systemd[1]: Started Music Player Daemon.
[ 26.798890] systemd[1]: Starting Shairport AirTunes receiver...
[ 26.805441] systemd[1]: Started Shairport AirTunes receiver.
[ 27.038694] systemd[1]: Starting Usb Automount (udevil)...
[ 27.045061] systemd[1]: Started Usb Automount (udevil).
[ 28.356891] usbcore: registered new interface driver snd-usb-audio
[ 28.888167] bcm2835-cpufreq: switching to governor performance
[ 28.888201] bcm2835-cpufreq: switching to governor performance
[ 29.064457] systemd[1]: Starting The PHP FastCGI Process Manager...
[ 29.301611] systemd[1]: Started The PHP FastCGI Process Manager.
[ 30.199117] FS-Cache: Netfs 'cifs' registered for caching
[ 30.200014] Key type cifs.spnego registered
[ 30.200137] Key type cifs.idmap registered
[ 30.387536] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 30.387616] CIFS VFS: Send error in SessSetup = -13
[ 30.388008] CIFS VFS: cifs_mount failed w/return code = -13
[ 73.085004] systemd[1]: Stopped Music Player Daemon.
[ 74.201626] systemd[1]: Starting Music Player Daemon...
[ 74.218286] systemd[1]: Started Music Player Daemon.
###### PHP backend ######
php version: 5.5.17
debug level: 0
Debug data collected in 2.477 seconds.
Karl M.
karlmorten
