[BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Re: [BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Postby Tom2112 » 29 Nov 2016, 04:21
Tom2112
Postby bloodnok » 12 Dec 2016, 03:22
bloodnok
Postby snafu » 10 Feb 2018, 19:35
Hmmm. When I run the "redis-cli.....", I get- "(interger) 0" displayed. Is that a good thing or a bad thing?
Then when I run the "refresh_ao" I get "command not found".
My guess is the refresh_ao error is a path related issue? Which folder does this command reside?
I'm using a HiFiBerry Dac+. It's working except the hardware volume control fails to work. Software enabled works, but it effects the sound quality. I'm hoping if I can get your command to work, it'll fix this.
snafu
Postby drfrink24 » 27 Mar 2019, 20:43
I've tried all the suggestions here, and I can't get HW volume control to work with HifiBerry Dac+ Pro and Pi2, I think its related to the fact that I can't get the audio_output mpd.config, as shown below from the guide to match the same syntax.
Any ideas?
#expected output
audio_output {
name "snd_rpi_hifiberry_dacplus"
type "alsa"
device "hw:1,0"
mixer_control "Master"
mixer_type "hardware"
mixer_device "hw:1"
auto_resample "no"
auto_format "no"
enabled "yes"
#my output
audio_output {
type "alsa"
device "hw:1,0"
mixer_control "Digital"
mixer_device "hw:1"
auto_resample "no"
auto_format "no"
enabled "yes"
Entire dump:
debug.zip
(19.67 KiB) Downloaded 933 times
drfrink24
Postby janui » 29 Mar 2019, 12:12
Postby rastus » 12 Apr 2021, 00:43
Hello janui,
long time no see. I hope you and yours are well.
Regards,
Rastus
rastus
Postby Savannah2024 » 21 Aug 2024, 09:03
Can you post here your debug informations?
Skysmotor sells the following products online: , , Hybrid Stepper Motor, Stepper Motor and can be purchased online if needed.
Savannah2024
