[BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Re: [BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Postby hondagx35 » 09 Jul 2015, 20:44
Postby coloscott » 10 Jul 2015, 15:18
Frank,
That worked! Excellent! Thanks so much for your help!
Scott
coloscott
Postby gjnieuwburg » 21 Jul 2015, 21:29
hello,
i can't seem to get this working either.
the output of
redis-cli hset acards_details snd_rpi_hifiberry_dacplus "{\"sysname\":\"snd_rpi_hifiberry_dacplus\",\"extlabel\":\"HiFiBerry DAC+ (I²S)\",\"mixer_numid\":\"1\",\"mixer_control\":\"Playback Digital\",\"hwplatformid\":\"01\",\"type\":\"i2s\"}"
is "(integer) 0
the output of refresh_ao is:
amixer: Unable to find simple control 'Playback Digital',0
Notice: Undefined offset: 0 in /srv/http/app/libs/runeaudio.php on line 1793
Notice: Undefined offset: 0 in /srv/http/app/libs/runeaudio.php on line 2275
Notice: Undefined offset: 0 in /srv/http/app/libs/runeaudio.php on line 2276
Warning: socket_write(): unable to write to socket [32]: Broken pipe in /srv/http/app/libs/runeaudio.php on line 99
anyone knows what could be wrong here?
thanks!
gjnieuwburg
Postby gjnieuwburg » 21 Jul 2015, 22:14
sorry!! missed the last pages
so tried all the other options now, but still can't get it working... :/
***edit*** fixed!! the blacklist thing worked
gjnieuwburg
Postby Bog » 21 Aug 2015, 01:10
hi everybody, I'm a complete noob and I never used linux or anything more complicated than windows 7. I have a hifiberry dac+ and switched to runeaudio from volumio because of its features (album covers, remote control, ecc). I managed to get it to work (to my surprise) but can't fix this hardware volume issue. can you please instruct me on how to do it step by step? consider the fact that when I read "access via ssh" my face looked like this :| . I tried to download putty but got stuck immediately.. I wish it was easier, I can't get it to work! please help me
EDIT: I managed to access via ssh ( :o ) using putty, to my rune IP (what is port 22 beside the IP in putty anyway??) and the default user and pass, wrote the code for the fix (I just don't know how to copy and paste in the terminal, f**k) but retrieved integer 0 error, and the refresh_ao resulted in command not found
EDIT 2: I did it, still don't know how but it works perfectly now :mrgreen:
Bog
Postby Jan1959 » 14 Oct 2015, 18:49
I also post it (already) in the rune audio 0.3 beta post.
Probably wrong so i put it here once more (or again).
Is there a version of runeaudio with the right hifiberry+ analog and HW volume for the raspberry 2B that works directly without the correction that is mentioned in this post. I am a complet noob in linux. Probably a version 0.31-beta. I wil save a lot of studying how linux, putty, shh etc works.
Thank you for your answer in advantage.
Jan1959
Postby PerLinden » 19 Oct 2015, 11:19
Thanks for great Work !
Feeling pretty stupid ! The command "refresh_ao" is not recognize by my distribution !
Seems it works for others, what am I doing wrong ? The HiFi Berry DAC + is installed, and the green LED on it is on when playing. The volume is 100%, which will be changed now !
Using RPI 2B
RuneOs: 0.3-beta
RuneUI: 1.3-beta
Hw-env: RaspberryPi 2
[root@runeaudio ~]#
[root@runeaudio ~]# redis-cli hset acards_details snd_rpi_hifiberry_dacplus "{\" sysname\":\"snd_rpi_hifiberry_dacplus\",\"extlabel\":\"HiFiBerry DAC+ (I²S) \",\"mixer_numid\":\"1\",\"mixer_control\":\"Playback Digital\",\"hwplatformid\" :\"01\",\"type\":\"i2s\"}"
(integer) 0
[root@runeaudio ~]# refresh_ao
-bash: refresh_ao: command not found
[root@runeaudio ~]# help refresh
-bash: help: no help topics match `refresh'. Try `help help' or `man -k refresh' or `info refresh'.
[root@runeaudio ~]# pwd
/root
PerLinden
Postby 123456 » 06 Nov 2015, 17:40
123456
Postby hondagx35 » 06 Nov 2015, 18:33
Postby °pdi° » 09 Nov 2015, 14:06
edit: change my mind
Klaus
°pdi°
