[BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Re: [BugFix] HiFiBerry DAC+ HW Volume (RuneAudio 0.3-beta)
Postby hondagx35 » 20 Feb 2016, 20:02
Hi maxchess,
you have to enable I2S on the settings page first.
@PeteB
He uses a Pi1 not a Pi2, so this will not work for him.
Postby maxchess » 20 Feb 2016, 21:47
Great thanks, OK that worked, now the system plays through the DAC+ but no hardware volume control, and software volume control doesn't work either with HiFiBerry selected.
config.sys doesn't contain anything dac related stuff, assume thats for Pi2.
So any thoughts on how I get hardware volume control going that the DAC+ says it supports?
maxchess
Postby maxchess » 20 Feb 2016, 22:04
Correction: software volume control does work, but not Hardware
maxchess
Postby mikbraga » 29 Feb 2016, 16:22
I'm trying to apply the fix, but after the execution of the first line of command, the refresh_ao command is not working and I don't get the Dac+ in the list of the output.
Running a Raspberry PI 2 + HifyBerry DAC+ Pro and RuneAudio 0.3 Beta
Is there something I'm missing?
mikbraga
Postby PeteB » 29 Feb 2016, 17:35
Postby hondagx35 » 29 Feb 2016, 17:38
Postby mikbraga » 04 Mar 2016, 10:56
Thanks for the support.
I did the kernel update and after the config.txt file fix the HiFiBerry DAC+ is now in the list.
With the nightly build (I did try this to use the android app) the HW volume control was working, but now, after a clean reinstall of the 0.3 beta + kernel update + config.txt edit I can't get the HW volume control working any more.
Do you need the nightly build for the hw volume control to work properly?
Thx
mikbraga
Postby PeteB » 12 Mar 2016, 06:03
Postby mikbraga » 15 Mar 2016, 10:19
Thank you, I'll try your tipe as soon as I find the time to gol back working on my Raspberry PI setup.
I'll post a feedback and my opinion about it here ;)
Have a nice day
mikbraga
Postby smallfat » 02 Apr 2016, 18:59
How to SSH login RP3?
Like ODROID?
Login ID: root
PW: runeaudio
RGDS
smallfat
