Hifiberry DAC+ not listed in MPD audio output menu (NEW)
Postby Remmy » 04 Jul 2016, 09:08
I have a similar problem as the one described here :
post16156.html
But the solution which was presented in the previous topic does not work for me.
Similarity :
Runeaudio works well, but the HifiBerry DAC+ is not listed in the MPD audio output menu.
I have a Raspberry 2, a HifiBerry DAC+ Pro, and V0.4 for RuneAudio (RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB)
Difference :
"I²S kernel modules" item gives me no choice and says "Enable I²S output by selecting one of the available sets of modules (in this version you have to edit /boot/config.txt), specific for each hardware. Once set, the output interface will appear in the MPD configuration select menu, and modules will also auto-load from the next reboot. "
I don't know how to edit this file (From a Mac) and what to put in it if I happen to be able to edit it.
Or is there another solution ?
Can someone here help me please ?
Remmy
