Hifiberry DAC +- Pro has header on P3?
Postby dirtylarry » 21 Dec 2017, 14:46
I just installed the Hifiberry Dac +- pro on to my Pi3, I noticed I have a 2 pin header on the board at P3, all the videos and pics I see online don't have this, I'm assuming this is recently added to the DAC? Is this for separate power supply connectivity? And if so do I still need to De-solder the resistor to accomplish this?
One more question, can anyone recommend a HAT or add on that will allow S-jack style headphones to be used and still get the sound throughput from the Dac?
Any help is greatly appreciated, thank you
Larry
dirtylarry
Re: Hifiberry DAC +- Pro has header on P3?
Postby janui » 21 Dec 2017, 17:38
Hi dirtylarry,
See here: https://www.hifiberry.com/build/documen ... er-supply/ and here: https://www.hifiberry.com/build/documen ... -i2s-dacs/ These documents are really difficult to find, the search engines seem to miss them. There are issues with an UART conflict on the Pi 3B, you need to disable the on-board Bluetooth, see here: post21171.html?hilit=uart%20hifiberry#p21171
Postby dirtylarry » 23 Jan 2018, 02:09
Thank you
dirtylarry
Postby michaeldoom » 30 Jan 2018, 11:06
Thanks!
That is absolute truth. Almost every day I . I consider that site pretty outstanding. I will try to find out even more games there.
michaeldoom
Return to Hi-Fi systems
