HifiBerry DAC+ Pro [solved for Raspberry B+]
Re: HifiBerry DAC+ Pro [solved]
Postby hondagx35 » 08 Nov 2015, 23:36
Re: HifiBerry DAC+ Pro [solved for Raspberry B+]
Postby bknarf » 23 Nov 2015, 11:45
Just to be sure, will there be a fix to get full hardware support for the HifiBerry Dac+ Pro in RuneAudio, without breaking the WiFi functionality? Or do we have to wait till version 0.4?
FrankB
bknarf
Postby RandirVithren » 26 Nov 2015, 09:48
hi all (sorry for my english)
i think i have the same problem like JeffD or bknarf.
after the successful kernel-update run my hifiberry dac+ pro very fine.
but since the update it isn't possible to connect to wifi.
although the pi detect the wifi-signal, but can't connect with it.
is there already a solution?
thx, randir
RandirVithren
Postby bknarf » 12 Feb 2016, 16:31
Any news on this? :)
bknarf
Postby hondagx35 » 12 Feb 2016, 18:02
Postby bknarf » 12 Feb 2016, 19:47
Sorry, I was referring to the issue of broken WiFi functionality, after doing a kernel update to get the driver support for the HifiBerry Dac+ Pro ... As I read in this topic, more people experienced this problem. So I was just curious if there is a fix. Or do we have to wait for the 0.4 release, to get a more recent kernel?
bknarf
Postby hondagx35 » 12 Feb 2016, 21:09
Postby bknarf » 15 Feb 2016, 16:49
As I am not using RuneAudio at this moment, I wanted to install it again and generate the debug info. But strangely enough, I can't get RuneAudio up and running again at all. The SD card won't boot. Odd, because if I put back Moode on it, it's working perfectly. I've checked the md5sum, extracted the archive again. The SD card is readable after I flashed Rune on it. But no booting :?
bknarf
