HifiBerry for Raspberri Pi B+
Postby skrodahl » 24 Jul 2014, 10:32
HifiBerry has just posted a preview of the new board for Raspberry Pi B+:
http://www.hifiberry.com/2014/07/previe ... erry-pi-b/
On a side note, if you were expecting better on-board audio from the new B+, you will be disappointed. The guys behind HifiBerry have done some measurements:
http://www.crazy-audio.com/2014/07/soun ... erry-pi-b/
-skrodahl
skrodahl
Moderator
Re: HifiBerry for Raspberri Pi B+
Postby Fishstix » 22 Sep 2014, 22:23
Nummers! Pretty photo. I just picked up a Pi B+ and this corresponding HiFiBerry DAC+. Somewhat different PCB layout than what is pictured; as I understand, this was a proto. The retail version is a very clean, very pretty build, and the hardware install is just as easy as you would hope. Press it together, no soldering. I am not finding RuneAudio software support as of 0.3 alpha (fair is fair; this is a pretty new board) so it will have to sit to the side for now. If you should pick this pair up, leave the DAC+ off until the software catches up; the onboard Pi B+ headphone jack won't work with the HiFiBerry installed. Or by the time you've read this, there might already be an update.....
I am finding that the native headphone jack on the B+ provides reasonable output, nothing stellar, but no pops or hissing. It pairs just fine with my tube amp for casual listening. I am certainly enjoying it until the DAC+ gets support, and curious what strides the DAC+ will make on the platform for serious listening.
Fishstix
Postby sammcj » 30 Sep 2014, 02:41
No S/PDIF / COAX out :(
sammcj
Postby Peter » 30 Sep 2014, 04:22
Peter
