HOW DO I CONNECT TO WIFI PLEASE
Postby MACKE » 03 Feb 2022, 20:08
RASPBERRY PI MODEL B+ V1.2
WITH IQAUDIO PIDAC+
Question 1. How do i enable wifi on the pi. Ive looked on network and i can only see Ethernet.
Question 2. What is the latest version of Rune Audio for this pi and can you provide a download link please.
DEBUG INFO FOLLOWS
###### System info ######
Linux version 3.12.26-1-ARCH (nobody@root-armv6-copy) (gcc version 4.8.2 20131219 (prerelease) (GCC) ) #1 PREEMPT Fri Aug 8 17:40:14 MDT 2014
system time: Thu Feb 3 18:24:19 GMT 2022
system load: 0.96 0.26 0.09 3/87 590
HW platform: RaspberryPi (01)
playerID: 01ce22edff80022f9116a029273a35ec69
###### System load statistics (procinfo -H) ######
Memory: Total Used Free Buffers
RAM: 482.42MiB 94.49MiB 387.93MiB 8.60MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Thu Feb 3 18:23:41 2022 Load average: 0.96 0.26 0.09 2/89 592
user : 00:00:15.67 42.5% page in : 58258
nice : 00:00:01.65 4.5% page out: 1100
system: 00:00:10.58 28.7% page act: 5113
IOwait: 00:00:00.56 1.5% page dea: 0
hw irq: 00:00:00.14 0.4% page flt: 189767
sw irq: 00:00:00.21 0.6% swap in : 0
idle : 00:00:08.02 21.8% swap out: 0
uptime: 00:00:37.61 context : 23712
irq 3: 3561 irq 66: 1
irq 16: 0 irq 75: 1
irq 20: 0 irq 77: 8032
irq 32: 12349 irq 79: 25
irq 52: 0 irq 80: 0
irq 65: 7 irq 84: 9320
mmcblk0 1737r mmcblk0p2 2r
mmcblk0p1 85r mmcblk0p5 1591r
eth0 TX 12.79KiB RX 5.55KiB ifb1 TX 0.00B RX 0.00B
ifb0 TX 0.00B RX 0.00B lo TX 166.72KiB RX 166.72KiB
###### Active processes (pstree) ######
systemd-+-agetty
|-avahi-daemon---avahi-daemon
|-avahi-dnsconfd
|-dbus-daemon
|-debug_collector---sh---pstree
|-devmon---udevil
|-dhcpcd
|-ifplugd
|-mpd---5*[{mpd}]
|-nginx---nginx
|-php-fpm---3*[php-fpm]
|-redis-server---2*[{redis-server}]
|-rpcbind
|-rune_PL_wrk
|-rune_SY_wrk
|-shairport---{shairport}
|-sshd
|-systemd-udevd
`-upmpdcli---7*[{upmpdcli}]
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k3.12.26-1-ARCH.
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [sndrpiiqaudioda]: snd_rpi_iqaudio - snd_rpi_iqaudio_dac
snd_rpi_iqaudio_dac
PLAYBACK devices: (aplay -l)
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
Subdevices: 1/1
card 1: sndrpiiqaudioda [snd_rpi_iqaudio_dac], device 0: IQaudIO DAC HiFi pcm512x-hifi-0 []
Subdevices: 1/1
PCM devices: (aplay -L)
null
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
default:CARD=sndrpiiqaudioda
snd_rpi_iqaudio_dac,
sysdefault:CARD=sndrpiiqaudioda
card 0:
Simple mixer control 'PCM',0
card 1:
Simple mixer control 'DSP Program',0
Simple mixer control 'Playback Digital',0
Simple mixer control 'Auto Mute',0
Simple mixer control 'Auto Mute Mono',0
Simple mixer control 'Auto Mute Time Left',0
Simple mixer control 'Auto Mute Time Right',0
Simple mixer control 'Clock Missing Period',0
Simple mixer control 'Deemphasis',0
Simple mixer control 'Volume Ramp Down Emergency Rate',0
Simple mixer control 'Volume Ramp Down Emergency Step',0
Simple mixer control 'Volume Ramp Down Rate',0
Simple mixer control 'Volume Ramp Down Step',0
Simple mixer control 'Volume Ramp Up Rate',0
Simple mixer control 'Volume Ramp Up Step',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=2,iface=MIXER,name='PCM Playback Switch'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
card 1:
numid=4,iface=MIXER,name='DSP Program'
numid=2,iface=MIXER,name='Playback Digital Switch'
numid=1,iface=MIXER,name='Playback Digital Volume'
numid=8,iface=MIXER,name='Auto Mute Mono Switch'
numid=9,iface=MIXER,name='Auto Mute Switch'
numid=6,iface=MIXER,name='Auto Mute Time Left'
numid=7,iface=MIXER,name='Auto Mute Time Right'
numid=5,iface=MIXER,name='Clock Missing Period'
numid=3,iface=MIXER,name='Deemphasis Switch'
numid=14,iface=MIXER,name='Volume Ramp Down Emergency Rate'
numid=15,iface=MIXER,name='Volume Ramp Down Emergency Step'
numid=10,iface=MIXER,name='Volume Ramp Down Rate'
numid=11,iface=MIXER,name='Volume Ramp Down Step'
numid=12,iface=MIXER,name='Volume Ramp Up Rate'
numid=13,iface=MIXER,name='Volume Ramp Up Step'
Output 1 (bcm2835 ALSA) is enabled
Output 2 (snd_rpi_iqaudio_dac) is enabled
###### mpd.conf ######
zeroconf_enabled "yes"
zeroconf_name "RuneAudio"
bind_to_address "/run/mpd.sock"
bind_to_address "any"
port "6600"
max_connections "20"
user "mpd"
group "audio"
db_file "/var/lib/mpd/mpd.db"
sticker_file "/var/lib/mpd/sticker.sql"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
auto_update "yes"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
volume_normalization "no"
audio_buffer_size "4000"
buffer_before_play "30%"
gapless_mp3_playback "yes"
audio_output {
name "bcm2835 ALSA"
type "alsa"
device "hw:0,0"
mixer_type "hardware"
mixer_device "hw:hw:0,0"
mixer_control ",0"
mixer_index "0"
dsd_usb "yes"
auto_resample "no"
auto_format "no"
enabled "yes"
audio_output {
name "snd_rpi_iqaudio_dac"
type "alsa"
device "hw:1,0"
mixer_device "hw:1"
mixer_control "Playback Digital"
mixer_index "0"
dsd_usb "yes"
auto_resample "no"
auto_format "no"
enabled "yes"
hardware platform: RaspberryPi
current orionprofile: OrionV3_iqaudio
kernel scheduler for mmcblk0: [noop] deadline cfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 139950
/proc/sys/kernel/sched_rt_period_us: 950000
/proc/sys/kernel/sched_rt_runtime_us: 950000
/proc/sys/kernel/sched_autogroup_enabled: 0
/proc/sys/kernel/sched_rr_timeslice_ms: 1
/proc/sys/kernel/sched_min_granularity_ns: 950000
/proc/sys/kernel/sched_wakeup_granularity_ns: 1000000
Error opening module snd_usb_audio
###### Systemd active startup scripts (ls -lah /etc/systemd/system/multi-user.target.wants/) ######
total 8.0K
drwxr-xr-x 2 root root 4.0K Sep 27 2014 .
drwxr-xr-x 6 root root 4.0K Aug 31 2014 ..
lrwxrwxrwx 1 root root 46 Aug 13 2013 avahi-dnsconfd.service -> /usr/lib/systemd/system/avahi-dnsconfd.service
lrwxrwxrwx 1 root root 47 Aug 10 2014 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 37 Aug 9 2014 nginx.service -> /usr/lib/systemd/system/nginx.service
lrwxrwxrwx 1 root root 39 Aug 9 2014 php-fpm.service -> /usr/lib/systemd/system/php-fpm.service
lrwxrwxrwx 1 root root 37 Jul 18 2014 redis.service -> /usr/lib/systemd/system/redis.service
lrwxrwxrwx 1 root root 51 Sep 3 2014 remote-fs.target -> ../../../../usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 43 Aug 9 2014 rune_PL_wrk.service -> /usr/lib/systemd/system/rune_PL_wrk.service
lrwxrwxrwx 1 root root 43 Aug 10 2014 rune_SY_wrk.service -> /usr/lib/systemd/system/rune_SY_wrk.service
lrwxrwxrwx 1 root root 36 Aug 13 2013 sshd.service -> /usr/lib/systemd/system/sshd.service
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,noatime,nodiratime,nouser_xattr,errors=remount-ro,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=242780k,nr_inodes=60695,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_prio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=22,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
logs /var/log ramfs rw,nosuid,nodev,noatime,mode=1777,size=1M 0 0
rune-logs /var/log/runeaudio ramfs rw,nosuid,nodev,noatime,mode=1777,size=10M 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
//192.168.1.248/Music /mnt/MPD/NAS/JukeBox cifs ro,relatime,vers=1.0,sec=ntlm,cache=none,username=music,uid=45,forceuid,gid=45,forcegid,addr=192.168.1.248,unix,posixpaths,serverino,acl,rsize=16384,wsize=17408,actimeo=1 0 0
###### Filesystem mounts - free space (df -h) ######
/dev/root 1.7G 698M 842M 46% /
devtmpfs 238M 0 238M 0% /dev
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 242M 288K 241M 1% /run
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 242M 4.0K 242M 1% /tmp
/dev/mmcblk0p1 90M 44M 47M 49% /boot
//192.168.1.248/Music 272G 222G 51G 82% /mnt/MPD/NAS/JukeBox
###### Loaded kernel modules ######
Module Size Used by
ecb 1891 0
md4 3351 0
nls_utf8 1259 1
cifs 442790 2
snd_soc_iqaudio_dac 2533 0
snd_soc_pcm512x 9034 1
cfg80211 440129 0
snd_soc_wm8804 7940 0
snd_soc_bcm2708_i2s 6202 2
regmap_mmio 2838 1 snd_soc_bcm2708_i2s
snd_soc_core 155972 4 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_iqaudio_dac,snd_soc_bcm2708_i2s
leds_gpio 2142 0
led_class 4162 1 leds_gpio
snd_compress 8351 1 snd_soc_core
snd_pcm_dmaengine 5533 1 snd_soc_core
i2c_bcm2708 4895 0
spi_bcm2708 4844 0
regmap_spi 1941 3 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_core
regmap_i2c 1685 3 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_core
bcm2708_dmaengine 5224 1
virt_dma 2309 1 bcm2708_dmaengine
snd_bcm2835 19609 0
snd_pcm 81802 4 snd_bcm2835,snd_soc_core,snd_soc_iqaudio_dac,snd_pcm_dmaengine
snd_page_alloc 5192 1 snd_pcm
snd_timer 20370 1 snd_pcm
snd 62046 7 snd_bcm2835,snd_soc_core,snd_timer,snd_pcm,snd_compress
bcm2708_rng 1044 0
rng_core 4159 1 bcm2708_rng
ipv6 319689 0
###### Network listening sockets (netstat -lnp) ######
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN 409/upmpdcli
tcp 0 0 0.0.0.0:6600 0.0.0.0:* LISTEN 406/mpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 422/shairport
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 119/redis-server 12
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 139/rpcbind
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 143/nginx: master p
tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 143/nginx: master p
tcp 0 0 0.0.0.0:82 0.0.0.0:* LISTEN 143/nginx: master p
tcp 0 0 0.0.0.0:83 0.0.0.0:* LISTEN 143/nginx: master p
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 117/sshd
udp 0 0 0.0.0.0:44157 0.0.0.0:* 132/avahi-daemon: r
udp 0 0 0.0.0.0:736 0.0.0.0:* 139/rpcbind
udp 0 0 0.0.0.0:5353 0.0.0.0:* 132/avahi-daemon: r
udp 0 0 127.0.0.1:41756 0.0.0.0:* 409/upmpdcli
udp 0 0 0.0.0.0:68 0.0.0.0:* 346/dhcpcd
udp 0 0 0.0.0.0:1900 0.0.0.0:* 409/upmpdcli
udp 0 0 0.0.0.0:111 0.0.0.0:* 139/rpcbind
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] STREAM LISTENING 4866 119/redis-server 12 /tmp/redis.sock
unix 2 [ ACC ] STREAM LISTENING 8552 482/php-fpm: master /var/run/php-command.sock
unix 2 [ ACC ] STREAM LISTENING 8555 482/php-fpm: master /var/run/php-db.sock
unix 2 [ ACC ] STREAM LISTENING 8558 482/php-fpm: master /var/run/php-display.sock
unix 2 [ ACC ] STREAM LISTENING 8054 406/mpd /run/mpd.sock
unix 2 [ ACC ] STREAM LISTENING 4498 1/init /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 5268 139/rpcbind /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 4503 1/init /run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 4522 1/init /var/run/rpcbind.sock
unix 2 [ ACC ] STREAM LISTENING 3007 1/init /run/systemd/private
unix 2 [ ACC ] SEQPACKET LISTENING 3022 1/init /run/udev/control
###### Network established sockets (netstat -np) ######
Active Internet connections (w/o servers)
tcp 0 0 127.0.0.1:80 127.0.0.1:57050 TIME_WAIT -
tcp 0 0 127.0.0.1:47740 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47683 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:57158 TIME_WAIT -
tcp 0 0 127.0.0.1:47724 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47688 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47668 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47697 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47710 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47701 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47706 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47752 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47679 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47660 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47690 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47715 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47693 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.173:46927 192.168.1.248:445 ESTABLISHED -
tcp 0 0 127.0.0.1:47720 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47756 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47746 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:57135 TIME_WAIT -
tcp 0 0 127.0.0.1:47663 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:60671 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:47558 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47672 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47739 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:57178 TIME_WAIT -
tcp 0 0 127.0.0.1:47703 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47667 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47686 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47696 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47731 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47754 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47709 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47738 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47749 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47743 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47730 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47641 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47684 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:60893 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:47714 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47670 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47729 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47713 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47680 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:6600 127.0.0.1:60806 ESTABLISHED 406/mpd
tcp 0 0 127.0.0.1:47704 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47735 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47717 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47727 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47732 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47723 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47699 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47741 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47664 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47689 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:82 127.0.0.1:57964 TIME_WAIT -
tcp 0 0 127.0.0.1:47725 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.173:60782 172.67.135.208:80 TIME_WAIT -
tcp 0 0 127.0.0.1:47671 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47695 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47722 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47691 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47556 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47712 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47685 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47640 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:60756 127.0.0.1:6600 TIME_WAIT -
tcp 6 0 192.168.1.173:80 192.168.1.94:50113 ESTABLISHED 144/nginx: worker p
tcp 0 0 127.0.0.1:47711 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47750 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47424 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47726 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47755 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:57233 TIME_WAIT -
tcp 0 0 127.0.0.1:47681 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47747 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:60603 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:47675 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47753 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47702 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:60806 127.0.0.1:6600 ESTABLISHED 409/upmpdcli
tcp 0 0 127.0.0.1:47707 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:57199 TIME_WAIT -
tcp 0 0 127.0.0.1:47734 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47698 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47659 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47465 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47568 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47718 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47708 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47757 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47737 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47669 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:57073 TIME_WAIT -
tcp 0 0 127.0.0.1:47700 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47678 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47665 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47719 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47751 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47742 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47716 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47661 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:56982 TIME_WAIT -
tcp 0 0 127.0.0.1:47674 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47744 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47736 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47662 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47728 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47692 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47748 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47466 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47682 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47705 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47673 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47694 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:47733 127.0.0.1:6379 TIME_WAIT -
Active UNIX domain sockets (w/o servers)
unix 2 [ ] DGRAM 3005 1/init /run/systemd/notify
unix 2 [ ] DGRAM 3025 1/init /run/systemd/shutdownd
unix 3 [ ] STREAM CONNECTED 8058 406/mpd
unix 3 [ ] STREAM CONNECTED 5368 143/nginx: master p
unix 3 [ ] STREAM CONNECTED 8067 121/php
unix 3 [ ] STREAM CONNECTED 9907 149/php
unix 3 [ ] STREAM CONNECTED 5179 134/dbus-daemon
unix 3 [ ] STREAM CONNECTED 8062 119/redis-server 12 /tmp/redis.sock
unix 3 [ ] DGRAM 3820 89/systemd-udevd
unix 3 [ ] STREAM CONNECTED 5178 134/dbus-daemon
unix 3 [ ] STREAM CONNECTED 5372 143/nginx: master p
unix 3 [ ] STREAM CONNECTED 5145 135/avahi-daemon: c
unix 3 [ ] STREAM CONNECTED 8179 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] DGRAM 3821 89/systemd-udevd
unix 3 [ ] STREAM CONNECTED 5181 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 5144 132/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 8061 121/php
unix 3 [ ] STREAM CONNECTED 5161 132/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 5180 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 9908 119/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 8934 119/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 4920 127/avahi-dnsconfd
unix 3 [ ] STREAM CONNECTED 8059 134/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 5369 143/nginx: master p
unix 3 [ ] STREAM CONNECTED 5147 1/init
unix 3 [ ] STREAM CONNECTED 8551 482/php-fpm: master
unix 3 [ ] STREAM CONNECTED 5373 143/nginx: master p
unix 3 [ ] STREAM CONNECTED 5200 132/avahi-daemon: r /var/run/avahi-daemon/socket
unix 3 [ ] STREAM CONNECTED 8550 482/php-fpm: master
unix 3 [ ] STREAM CONNECTED 8071 406/mpd /run/mpd.sock
unix 3 [ ] STREAM CONNECTED 8178 422/shairport
unix 3 [ ] STREAM CONNECTED 8932 584/php
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: ifb0: mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether ba:f7:4d:c0:50:6c brd ff:ff:ff:ff:ff:ff
3: ifb1: mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether e2:b0:06:c9:d3:33 brd ff:ff:ff:ff:ff:ff
4: eth0: mtu 1000 qdisc pfifo_fast state UP group default qlen 4000
link/ether b8:27:eb:47:b7:69 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.173/24 brd 192.168.1.255 scope global eth0
###### Network interfaces (ifconfig) ######
eth0: flags=4163 mtu 1000
inet 192.168.1.173 netmask 255.255.255.0 broadcast 192.168.1.255
ether b8:27:eb:47:b7:69 txqueuelen 4000 (Ethernet)
RX packets 49 bytes 6046 (5.9 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 93 bytes 13515 (13.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 0 (Local Loopback)
RX packets 3926 bytes 187578 (183.1 KiB)
TX packets 3926 bytes 187578 (183.1 KiB)
MACKE
Re: HOW DO I CONNECT TO WIFI PLEASE
Postby Ears of Tin » 03 Feb 2022, 22:38
Here is the latest and greatest version:
https://github.com/rern/rAudio-1
The way I connect to WiFi is to edit the file wifi0 on the SD card before inserting into the Pi. Notes from the github site:
Edit template file - name and password.
Rename wifi0 in BOOT to wifi
Edit SSID and Key.
You can also temporarily connect by Ethernet or hotspot, then enter your WiFi credentials and reboot.
You may have to query your router to find the IP address on the Pi if you use the first method.
Ears of Tin
Postby MACKE » 04 Feb 2022, 08:36
Thank all ok now
MACKE
Users browsing this forum: Bing [Bot] and 0 guests
