How to assembly rune in the i386 VirtualBox machine?
Help wanted! How to contribute to RuneAudio project
Postby Dukobpa3 » 22 Sep 2014, 11:48
Hi. I've got the rune assembled from git on clean R-Pi.
For now I want to do this on the virtual machine.
The problem is in a few packages that the RuneOS.git contains and they assembled for ARM architecture.
Should I use only your version of packages or I can use the same from main pacman repos?
Dukobpa3
Re: How to assembly rune in the i386 VirtualBox machine?
Postby ACX » 22 Sep 2014, 12:50
You need to recompile all the custom packages for each different architecture.
You can take inspiration from the (now outdated and incomplete) "dev" cookbook:
https://github.com/RuneAudio/RuneOS/blo ... opment.txt
Postby Dukobpa3 » 22 Sep 2014, 12:56
Thanx
Dukobpa3
Return to Help the project
