How to let Pi 2 and Hifiberry DAC+ get work with RUNE ?
Re: How to let Pi 2 and Hifiberry DAC+ get work with RUNE ?
Postby jack » 19 Mar 2015, 03:34
Dear Frank,
Thanks for your reply.
I hope the later release image can work on the B+ too.
By the way, I found when I open the Library the USB storage show (5) but I only got 3 in fact.
Is it bug?
Jack
jack
Postby ACX » 19 Mar 2015, 11:47
Postby RaspiPie » 23 Jan 2016, 23:15
RaspiPie
Postby wocowboy » 24 Jan 2016, 01:02
I have a Raspberry Pi 2 Model B and I have installed Runeaudio .4(build:beta-20141216) and am trying to get a Hifiberry Digi+ board to work with it. The board works fine with Volume, Max2Play and Hifiberry's modified Raspbian, so I know there is no problem with the board itself.
I edited the config.txt file, removing the comment # on the line regarding the Hifiberry Digi but that had no effect at all.
I noticed there is a commented out line near the top of the config.txt file with i2s and wording that the default is "off" and to enable it, change to "on". I don't know how to do this. Do I uncomment the line and change that line to i2s=on? Or do I do anything to that line at all.
I really don't know how to do any more to get this card working, there is nothing in these forums specifically relating to the Hifiberry Digi+, doing a search produced no results.
Has anyone had any luck getting this card to work, and if so, what are the DETAILED instructions for doing so. Thanks very much in advance for any response.
wocowboy
Postby hondagx35 » 24 Jan 2016, 01:34
Postby hondagx35 » 24 Jan 2016, 01:56
Postby RaspiPie » 24 Jan 2016, 11:28
RaspiPie
Postby hondagx35 » 24 Jan 2016, 11:57
Postby RaspiPie » 24 Jan 2016, 13:17
RaspiPie
Postby hondagx35 » 24 Jan 2016, 13:39
