How to prevent automatic audio output switching? (solved)
Postby tmilovan » 11 Sep 2016, 11:06
I'm using external USB DAC that is set to go to standby when it is not used. Whenever that happens sound output is automatically switched to default and I have to manually switch MPD to external DAC again whenever I turn it on.
Is there a way to prevent this behavior and just let the audio output stay configured to use the external USB DAC all the time?
Thanks.
tmilovan
Re: How to prevent automatic audio output switching?
Postby hondagx35 » 11 Sep 2016, 17:00
Hi tmilovan,
on startup Rune checks if the current selected device is available.
If not it tries to find an other output device.
This is done in rune_SY_wrk see .
You can try to uncomment this line.
The file to edit is /var/www/command/rune_SY_wrk
Postby tmilovan » 11 Sep 2016, 17:25
Thanks for the reply. Unfortunately that does not affect the problem. As soon as I switch the external USB DAC off, mpd switches to the next available card and stays there until I switch the DAC on again, and manually select it from the settings.
tmilovan
Postby hondagx35 » 11 Sep 2016, 17:38
Postby tmilovan » 11 Sep 2016, 18:41
Great, that's it. Thanks.
tmilovan
