How to rotate Dakboard display?
Postby HoumirKinkar » 13 Jun 2024, 11:14
I put Dakboard OS on my Pi 3B and am using the free edition, which just supports landscape display. Adding display_rotate=1 to the config file using sudo nano /boot/config.txt should turn on the display, according what I read on forums. Still, the display does not rotate following this modification. Is another config file Dakboard utilizes, or might the constraints of the free account prohibit this change? I need the display in portrait orientation to match the wall mount, hence any help would be much valued.
HoumirKinkar
Re: How to rotate Dakboard display?
Postby toddporch » 12 Oct 2024, 19:22
toddporch
