How to sort folder views?
Postby vershner » 08 Apr 2015, 00:23
Got my Pi yesterday and installed Rune. So far it's looking and sounding good.
I have one issue though: - When I mounted a network share, the files and folders appeared alphabetically sorting in the library. However, when I mounted a usb drive the files and folders are not sorted all all. Is there a way to sort them?
vershner
Re: How to sort folder views?
Postby LeVolatile » 11 Apr 2015, 19:36
Did you try to update the Library? There is a sub-menu at the right of each folder. Click on it from your root folder and choose "Update this folder".
LeVolatile
Postby vershner » 14 Apr 2015, 14:57
I'm pretty sure it was updated. I can't test it now because I tried updating Rune to recognise my Hifberry Amp and it refused to boot. I'm using Volumio for now as that updated successfully and recognised the Amp, but I might try Rune again once 0.4 is out.
Interestingly Volumio seems to have the same problem sorting Usb mounts.
vershner
