How to unmute Dragonfly DAC
Postby doxyq3 » 10 Sep 2014, 21:49
How can I unmute my Dragonfly dac in Runeaudio?
It works fine with Volumio.
Setup:
Raspberry pi B+ v1.2
8 gB Sandisks ultra w/ runeaudio (latest alpha and beta)
Audioquest Dragonfly
several USB drives
Thanks!!!
doxyq3
Re: How to unmute Dragonfly DAC
Postby cmh714 » 10 Sep 2014, 22:48
ssh into the Pi and use alsamixer, select F6 to choose the DragonFly and then hit the M key to unmute.
GL
Postby ACX » 10 Sep 2014, 22:48
Postby doxyq3 » 11 Sep 2014, 19:45
Thanks!!!!!!!
Volume was unmuted but set to minimum, up arrows raised volume to max and sound works now :D
But..... the hardware volume control doesn't work and sound pauses a second every 2 seconds on 24bit/192k files :(
Software volume works but I would rather us the DACs hardware volume like in Volumio and 16bit/44k & 24bit/96k files play fine.
doxyq3
Postby ACX » 11 Sep 2014, 20:44
Please take a look at this thread and see if it can help you:
audioquest-dragonfly-t291.html
Postby doxyq3 » 11 Sep 2014, 21:59
When in software volume mode, volume will vary and all formats 16bit & 24bit - 44k-192k files play fine.
Hardware volume mode is the problem, with no volume control and 24bit 192k files stuttering.
Typing aplay -l shows:
card 0: ALSA [bcm2835 ALSA], device 0 bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1 bcm2835 ALSA [bcm2835 IEC958/HDMI]
subdevices: 1/1
card 1: Dragonfly [Audioquest Dragonfly], device 0: Usb Audio [Usb Audio]
I'm sorry but I'm totally ignorant with Linux. I don't understand a lot of the posts. Thank you for bearing with me.
doxyq3
