HOWTO: C1+ with other I2S DACs like Audiophonics ES9023
ODROID related support
Postby gkkpch » 24 Aug 2015, 14:49
refer to this post on the Odroid-C1+ forum to see how you can connect other I2S DACs,
like the 24bit/192Khz Teradak ES9023 or the Audiophonics ES9023, to an Odroid-C1+:
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Re: HOWTO: C1+ with other I2S DACs like Audiophonics ES9023
Postby jazzaj » 24 Aug 2015, 17:41
Odroid C1+ (/regulated linear PSU) > Audio-gd NFB-1 (with Amanero384 combo) > Audio-gd Precision 2 > Triangle Lyrr 222
jazzaj
Postby gkkpch » 24 Aug 2015, 19:19
Hi jazzaj,
the image for the C1+ defaults to "DAC enabled" (preset in /boot/boot.ini).
You do not have to change anything manually.
EDIT!!
Sorry, I was wrong, it does not. Currently you do need to enable the DAC in boot.ini, see the following post from Frank:
@Frank: can this can be changed in a future update?
A C1 will work wenn boot.ini is set to "enabledac", it is perhaps not quite as efficient for a C1 (doubt if you will notice) but makes it easier for less experienced users.
gkkpch
Postby Tinitus » 25 Aug 2015, 08:52
Hi Gé,
that will be helpful for lots of people thumbs up for the good work.
Uwe
Tinitus
Postby gkkpch » 18 Sep 2015, 19:02
There is another one that works with a C1+ :
Dirt cheap for a 32bit/384Khz device...
gkkpch
Postby jazzaj » 22 Sep 2015, 14:10
Hi all,
I tried to make a I2S cable for my Audio-gd NFB1 (ES9018). I'd asked Kingwa from Audio-gd about connection from the I2S output to the RJ45 input and he said I was right (see below) ...
I enable DAC in boot.ini (even if my DAC is ES9018 and not PCM5102) but unfortunately, I can't have sound fron my C1+...
Connections for the RJ45 pin map is (ES9018, so MLCK is going to GND):
Pin 1 : SDATA
Pin 3 : LRCK
Pin 5 : SCLK
Pin 2,4,6,7,8 : GND
And the map for Odroid 7 pins is :
Pin 1 : GND
Pin 2 : I2S data in (reserved)
Pin 3 : 5V
Pin 4 : I2S MCLK (Master Clock)
Pin 5 : I2S LRCLK (LR Clock)
Pin 6 : I2S SCLK (Bit Clock)
Pin 7 : I2S Data Out (for DAC)
So my cable's map, according to Kingwa, is (RJ45>Odroid 7 pin) :
[RJ45]Pin 1 (SDATA) > [odroid]Pin 7 (I2S Data Out)
[RJ45]Pin 3 (LRCK) > [odroid]Pin 5 (LRCLK)
[RJ45]Pin 5 (SCLK) > [odroid]Pin 6 (SCLK)
[RJ45]Pin 2,4,6,7,8 (GND) > [odroid]Pin 1 (GND)
And no sound :/
I tried to do the same for my old RPI2 without more success but probably because of the DAC interfaces in /boot/config.txt that need I2C bus response (see )
But this time, I don't understand why it goes for Teradak Sabre ES9023 or Audiophonics Sabre ES9023 and not for the NFB1 :twisted:
jazzaj
Postby gkkpch » 22 Sep 2015, 18:23
what happens if you do not connect MCLK at all (instead of connecting to GND)?
And how is it powered?
gkkpch
Postby jazzaj » 22 Sep 2015, 19:21
All the pins of a RJ45 must be connected. And the Audio-gd boss said that my map is right (I guess he knows what he says :))
And my DAC is 220v connected :
jazzaj
Postby odroider » 02 Oct 2015, 10:25
What is the over-sample value on your ES9018 DAC mclk input pin?
As far as I know, ODROID-C1+ mclk output is 256FS at 44.1Khz~192Khz and 128FS ~384Khz.
It seems your DAC doesn't accept mclk signal.
odroider
Postby hondagx35 » 02 Oct 2015, 14:17
Return to ODROID
