https acccess to Rune
Postby rasti » 28 May 2015, 18:41
is it possible to access Rune Audio UI not by http only but also by https as an option ?
I am asking because I would like to include the Rune UI as an iframe in my home automation server.
And, in an iframe http and https should not be mixed
=> http://www.tinywebgallery.com/blog/ifra ... -and-https
Since my home automation system is accessible from the outside internet, I must use https
Ralf
rasti
Re: https acccess to Rune
Postby hondagx35 » 29 May 2015, 21:40
Hi Ralf,
yes it is possible, but it requires a lot of configuration work on .
You also have to provide the necessary keys.
Postby rasti » 29 May 2015, 22:28
Thanks !
I googled a bit and found a step by step instruction, but for ubuntu not arch !
https://www.digitalocean.com/community/ ... untu-12-10
I am already stuck at step 1. (get a tool, here apache2-utils, to produce the encrypted passwd.
pacman -Syu apache2-utils => results in "target not found"
Step 2 is less or more clear
Step 3 is unclear. I thought that the file to be edited is /etc/nginx/nginx.conf
but I cannot find the following lines at all:
listen portnumber;
server_name ip_address;
Step 4: is less or more clear
Can you help ?
Ralf
rasti
