i2S port \ DAC SABRE MK2 ES 9018 HELP !!
Re: i2S port \ DAC SABRE MK2 ES 9018 HELP !!
Postby alvaron » 13 Oct 2016, 23:21
this means the C2 i2s signal levels are stronger than pi3?
alvaron
Postby dunghnguyen » 14 Oct 2016, 03:50
dunghnguyen
Postby dunghnguyen » 14 Oct 2016, 04:00
dunghnguyen
Postby alvaron » 14 Oct 2016, 18:04
ok
I have an XMOS USB card that has i2s and spdif out
but then you have to connect the Pi3 via USB to this XMOS USB in order to
get i2s out?
thanks for the information.
will let you know if I find any other solution with the Pi3
alvaron
Postby hondagx35 » 14 Oct 2016, 22:05
Postby alvaron » 14 Oct 2016, 22:18
Thanks Frank
will follow your instructions and use the dtoverlay = sabreberry32
will let you know if it works
I have i2s param enabled already
Alvaron
alvaron
Postby dunghnguyen » 15 Oct 2016, 02:19
dunghnguyen
Postby dunghnguyen » 15 Oct 2016, 03:15
dunghnguyen
Postby hondagx35 » 15 Oct 2016, 08:49
Postby dunghnguyen » 15 Oct 2016, 09:36
dunghnguyen
