i2S port \ DAC SABRE MK2 ES 9018 HELP !!
Re: i2S port \ DAC SABRE MK2 ES 9018 HELP !!
Postby dunghnguyen » 15 Oct 2016, 09:49
dunghnguyen
Postby hondagx35 » 15 Oct 2016, 10:53
Postby dunghnguyen » 15 Oct 2016, 11:24
dunghnguyen
Postby hondagx35 » 15 Oct 2016, 15:46
Hi all,
sorry my fault.
The driver is not for the ES9018K2M but for SABRE9018Q2C.
Postby alvaron » 15 Oct 2016, 16:12
Hi Frank and dunghnguyen
thanks for all the help
I went with all instructions and the sabreberry32 does not appears on the runeaudio MPD
had to go back to enable sabre ES9018DAC with old normal settings but just able to play back 44.1khz
web radio stations.
Best Regards
alvaron
Postby dunghnguyen » 15 Oct 2016, 16:34
dunghnguyen
Postby hondagx35 » 15 Oct 2016, 16:57
Postby alvaron » 15 Oct 2016, 19:11
Hi Frank
I changed MPD config as you said....and did not reboot just rebooted the mpd config file as instructed
when I go back to runeaudio and opened the MPD option I get a message that said that the mpd config file
has been changed do you want to go to the default or edit....I went to the edit and checked the mpd config and the
format "*:24:*" was there...
then hit the save but it just stay there. I reopened MPD menu again and the same message appears the mpd config has been changed etc...
alvaron
Postby alvaron » 15 Oct 2016, 19:40
Hi Frank
I have it working now......
I did not pull down the mpd menu
just went to the USB flac memory stick and it played 100 percent no.....white noise at all
I was wondering if Audiophonics from France sells the exact same DAC with the pi3 option
and worked for them...
I still have a question.....how do you get rid of that warning sign when you pull down the mpd menu?
and off topic.....I have been experiencing problem adjusting the official 7 inch back lilght...have been
looking at the forum but no direct post have been found about the subject
again Frank many thanks for all the help
alvaron
Postby hondagx35 » 15 Oct 2016, 21:46
