Idle problem
Idle problem
Postby Sergey » 24 Jan 2015, 16:20
Hello!
I am have problem: when Rpi long time in idle, and music stoped, RuneUI loose conection with MPD.
Also at this time Android client normaly work with MPD.
Sergey
Re: Idle problem
Postby ACX » 24 Jan 2015, 17:57
That should not happen, I usually leave my Rpi always powered on and I never faced that issue before.
Are you running a default installation updated via gitpull?
Do you have voltage dropdowns on your power line?
Re: Idle problem
Postby Sergey » 27 Jan 2015, 16:37
I saw it when power off NAS but not RPi.
After update RuneUI from git it work normaly at this time!
Sergey
Re: Idle problem
Postby ACX » 27 Jan 2015, 19:28
So has the problem disappeared after the update?
