Incomplete library loading & Wifi enable / disable
Re: Incomplete library loading
Postby cristache » 26 Aug 2021, 22:30
cristache
Postby cmh714 » 26 Aug 2021, 22:44
Well for bit perfect its on the Player tab in Settings, set to No Volume.....and then on the System tab you can try some of the Sound Profiles. The differences are super subtle and even with serious speakers I dont hear too much difference, but I use the RuneAudio profile.
I dont use any other features so I have everything else turned off or disabled......just pure music :)
Postby cristache » 26 Aug 2021, 23:05
cristache
Postby cristache » 27 Aug 2021, 00:17
Happy update...
After few hours :| of waiting the new stable version find all "lost" folders and everything work fine.
It's strange but something is unclear for me at BIT perfect settings. Both switches should be on Grey or on Blue ... ?
I ask that because when I play some dsf 64 / 128 file, my DAC receive converted file and when I activate DoP , my DAC receive DSD file without conversion via USB ... So the switch ( dop ) in my understanding should be off ( grey ) to receive unaltered file but DAC RECEIVE PCM reconverted .. so my conclusion is both switches should be on Blue, who means no volume and no DoP .
I was somehow clear. DAC work with native DSD . On PC with all drivers installed and settings only DSD same files play with same message on screen USB DS 64, and when are converted the message could be USB 384 k ( depends on bit depth of the original file ) . Also on Moode settings as output I have USB 384 k converted file from dsf dff files - dsd 64/128/256 .
Here are my DAC specifications:
S/PDIF 24bit 44.1-192k PCM, DSD64
AES/EBU 24bit 44.1-192k PCM, DSD64
USB 32bit 44.1-384k PCM, DSD64-512
OPTICAL 24bit 44.1-176k PCM, DSD64
I2S (LVDS) 32bit 44.1-384k PCM, DSD64-512
Something is missing or switches are on right position and I have burnnn brain
Thank you for all patience
Looking forward .... after answers
Cristache
cristache
Postby cmh714 » 27 Aug 2021, 02:05
Well for DSD I cant help as my DAC doesnt do DSD.....I would think if that switch is grey its native DSD and if blue it would be doing conversion to PCM but not sure......maybe post your question on the git pages as I think rern watches that more often...
Postby cmh714 » 27 Aug 2021, 02:06
Click on the ? question mark next to the button for the help description, maybe that will help.
Postby cristache » 27 Aug 2021, 15:55
cristache
Postby cristache » 28 Aug 2021, 08:05
cristache
Postby cristache » 09 Sep 2021, 13:14
Hello Hi-fi and Pi enthusiasts ....
Now I'm using the last version of Rune Audio and all my audio library was loaded form A to Z ... :D
The new UI is very cozy and nice to navigate but I'm try to find how to verify if the wifi and bluetooth was enable or disable on my Pi3 B ver 1.2 board ?
I try to find on forum and the answer but on /etc/modprobe.d/raspi-blacklist.conf I did't find any file to modify.
I'm wondering with the last version of rune audio, on system page if wifi and bluetooth was disable will not be also on pi3 board ? or I need to edit /boot/config.txt and add this two lines: dtoverlay=pi3-disable-wifi
and dtoverlay=pi3-disable-bt
Thank you in advance for your support
Cheers
Cristache
cristache
