Infineon Amp HAT support ?
Postby ceejayemm » 22 May 2020, 22:42
Any version of RuneAudio likely to support this interesting HAT ?
Chris
ceejayemm
Re: Infineon Amp HAT support ?
Postby rern » 25 May 2020, 08:29
now has it in I2S module list.
Please report the result.
Postby ceejayemm » 01 Jun 2020, 20:24
Rern
Thanks for making this change to implement this new HAT Amp.
I have just taken delivery of the new Merus Amp HAT, installed RA+e3 on a new PI Zero W, using the wifi0 file as a template for the wireless settings which seems OK,and applied the 20200527 updates which suggests the wireless is working OK. I have configured the system via the web pages, specifying the I2S Module as the new Merus Audio Amp. The Sources and Network pages were also configured correctly without any problems. I then moved on to the MPD settings, however the MPD page will not render at all. I disabled the I2S Module and I WAS then able to access the MPD page. Switched back to the Merus and the MPD page was not accessible again.
It would seem that there is something in the Merus Audio Amp setup which is interrupting access to the MPD settings page. What might that be ?
Chris
ceejayemm
Postby rern » 02 Jun 2020, 05:30
Postby ceejayemm » 02 Jun 2020, 09:49
ceejayemm
Postby ceejayemm » 02 Jun 2020, 11:36
ceejayemm
