Install open VPN client (apt-get update) (solved)
Postby frengo » 09 Apr 2016, 10:08
Hello, I am Frengo .... how are you?
I wrote about the command line interface through SSH Putty
I try to login as root and write apt-get update to get the packages Linux updates, but I get:
-bash: apt-get: command not found
Does anyone know why? There 's some way to unlock?
Thanks in advance.
frengo
Re: apt-get update
Postby hondagx35 » 09 Apr 2016, 10:19
Re: apt-get update
Postby frengo » 10 Apr 2016, 22:29
Thank You so much, hondagx35. Now I know that I can type pacman -Syu to update my system.
THANX.
frengo
Re: apt-get update
Postby hondagx35 » 10 Apr 2016, 22:59
Re: apt-get update
Postby frengo » 11 Apr 2016, 10:59
Yes, but i need to install open VPN client on Odroid C1+ to reach it via web mobile (3G/4G).
I can't use two Odroid (one for Rune and one for reach it......)
frengo
Re: apt-get update
Postby hondagx35 » 11 Apr 2016, 22:05
Re: apt-get update
Postby frengo » 13 Apr 2016, 14:29
From time to time I participate with a friend to the creation of something new for a small local private radio. They have a repeater in the mountains and they need a pcm quality remotized player to send music when sometimes goes faulty radio uplink that connects the studios with the repeater......
frengo
Re: apt-get update
Postby frengo » 09 May 2016, 22:45
I installed openvpn with:
pacman -Sy openvpn
but while on Debian I wrote:
service openvpn restart
and then:
service openvpn status
and the service was restarted fine, here on Archlinux to do the same thing I typed:
systemctl restart openvpn
and then:
systemctl status openvpn
but it gives me the following errors:
Failed to restart openvpn.service: Unit openvpn.service failed to load: No such file or directory
and
-bash: $: command not found.
What are the correct commands ?
THANX
frengo
Re: apt-get update
Postby hondagx35 » 10 May 2016, 11:10
Re: apt-get update
Postby frengo » 10 May 2016, 16:11
Actually I have to install OpenVPN only as Client (not as Bridge) but I see that I have always a large amount of error messages.
On Debian I succeeded to make working fine OpenVPN in seconds ....
apt-get install openvpn
then:
now copy the certificates, the key and config files in /etc/openvpn with:
cp ca.crt /etc/openvpn
cp client.crt /etc/openvpn
cp client.key /etc/openvpn
cp client.ovpn /etc/openvpn
-To connect to the server type on /etc/openvpn:
openvpn --config client.ovpn & exit
And the Client connect to the server.
I use the ODROID C1 +. Perhaps the codes are different from those for the Raspberry ?
frengo
Users browsing this forum: Bing [Bot] and 30 guests
