Installing Alsaequal manually
ODROID related support
Postby The Reverend » 30 Jan 2016, 16:00
Howdy,
is there a way to manually add alsaequal? I am running a C1+ with the Hifi shield.
I used
pacman -S alsaequal
but it seems alsaequal is not in the repository. I found quite a good guide on how to configure alsaequal to work with mpd. The high frequency responce of the Hifi shield could need a little tweaking. Atm i just use the tone controls of my preamp but i would like to build a new preamp myself and i could leave out the tone control circuitry when there is a software equalizer running.
The Reverend
Re: Installing Alsaequal manually
Postby The Reverend » 30 Jan 2016, 20:54
The Reverend
Postby hondagx35 » 31 Jan 2016, 01:12
Postby The Reverend » 31 Jan 2016, 19:02
Thanks for the tip. So far so good, my problem now: where is the asound.conf file so i can add the equalizer device?
The Reverend
Postby The Reverend » 31 Jan 2016, 20:06
Ok, alsaequal is installed and running but i cant add it as output device to the mpd manually.
When i edit the mpd manually a waring screen pops up in the MPD config window and thats it. If i choose edit manually and save the changes the warning window still pops up. If i cant select the equal plugin as output device its not working.
The Reverend
Postby The Reverend » 01 Feb 2016, 02:00
And its finally up, running and working.
I can write a little how to guide if anyone is interested. But this needs some experience with Linux in general and manual file editing. On the other hand you cant really brake anything, you can always reload a working image to the sd card.
System load has not increased at all, next thing i will try isusing the mbeq plugin but for now i am pleased an sound is great.
The Reverend
Postby odroider » 02 Feb 2016, 14:17
I am also really interested in the equalizer.
Please share an instruction how you could install the Alsaequal package. :mrgreen:
odroider
Postby The Reverend » 02 Feb 2016, 18:02
Here you go:
The Reverend
Postby ACX » 03 Feb 2016, 12:18
Postby odroider » 04 Feb 2016, 08:21
odroider
Return to ODROID
