iPhone 4 loads up Rune Audio. iPhone 6 does not
Postby SilverBlade » 23 Feb 2018, 18:19
Just as the title says, my old iPhone 4 can load the Rune Audio UI almost instantly, yet on my newer iPhone 6, it never loads. The arrows just keep going around and around, not doing anything.
It doesn't matter if my iPhone 6 is connected to wifi through 5G, 2.4G, my router or my wireless extender. The iPhone 4 will load no matter how it is connected to my router, directly or through the extender.
SilverBlade
Re: iPhone 4 loads up Rune Audio. iPhone 6 does not
Postby janui » 23 Feb 2018, 19:29
Hi SilverBlade,
If you use a static IP address with Rune, check the address which your iPhone 6 has been allocated. You will get this sort of behaviour if both devices have the same IP-address. If this is not the case and you need more help, please post your debug information.
PS My iPhone 6 works just the same as all my other devices. I can assure you that the phone is not the problem.
Postby SilverBlade » 23 Feb 2018, 22:01
SilverBlade
Users browsing this forum: Bing [Bot] and 10 guests
