IR Receiver & Remote support
Re: IR Receiver & Remote support
Postby pmoorhead » 15 Nov 2014, 15:55
thanks Frank.
almost got it working. lirc web pages running etc, but commands weren't having any effect.
checking by running irsend command line showed irsend: hardware does not support sending, so obviously my config isn't being picked up somewhere along the way.
I'm giving up at this point and reverting to bare MPD on Debian since I more or less know what I'm doing on Debian.
Shame - rune is so much faster to load than mpod on an ipad, and the android and windows mpd clients are all very basic.
it all works with volumio, but volumio can't handle the number of tracks in my sources - a bug that goes way back and they don't seem to care about. I guess my best hope is that they fix it some time.
Had I got it working, the next challenge would have been to hack the runeaudio ui to embed a link to the ir control web page into the main rune page (the ir control web page is also runing on nginx, but on port 3000).
I had thought of raising a feature request for the ability to add custom links into the home screen (e.g. via a config file) but unless someone else has got something like this working, not of value.
thanks again.
pmoorhead
Postby bower » 13 Jan 2015, 21:16
bower
Postby tatoosh » 24 Jan 2015, 15:17
tatoosh
Postby yjo » 07 Feb 2015, 14:50
yjo
Postby den_hr » 15 Feb 2015, 22:05
den_hr
Postby den_hr » 18 Feb 2015, 22:52
Luckily, I got this working, as explained in another thread. In short, I used some files which were not necessary, and which only messed things up :)
den_hr
Postby bower » 22 Apr 2015, 20:39
ExecStartPre=/usr/bin/sh -c "sleep 3" does the trick, thank you, it works!
Thank you very much!
bower
Postby XploD » 06 May 2015, 21:30
I'm trying to get LIRC to work but this Archlinux is a pain in the a** :evil: I was using LIRC successfully on Debian multiple times but here I can't since there are no step-by-step fully-working tutorials. So I managed to install LIRC, I run irrecord, it successfully reads commands from my remote so I created a config file and put it to /etc/lirc/lircd.conf.d/lircd.conf but what now? I tryed to restart service with systemctl restart lircd.service and systemctl restart lircd but when I run irw and press keys, nothing happens.
Can you help me? What am I missing?
Also, how do I "connect" LIRC with RuneAudio later? Is it automatically reacting to commands like KEY_PLAY or I'm supposed to write a program to pass remote's commands to RuneAudio?
Music taste:
Hi-Fi:
Mixer: Nady Audio MM-242
XploD
Postby den_hr » 07 May 2015, 14:44
den_hr
Postby neanderthaler » 10 May 2015, 19:58
neanderthaler
