IR remote with newer KerneL
Postby s.k. » 16 Nov 2019, 22:16
Since kernel 4.19 the lirc-rpi driver was removed.
Now you have to use the gpio-ir.
Does anyone manage successfully to install his IR remote with the newer (4.19.xx) Kernel?
Stavros
s.k.
Re: IR remote with newer KerneL
Postby s.k. » 19 Nov 2019, 13:07
I am the only one who have implement a IR remote in previous builds and likes to experience with Rern’ s new achievements ?
That’s really strange !
No one faced similar problem ?
s.k.
Setup an IR remote on Rern’s new achievements
Postby s.k. » 21 Nov 2019, 09:43
Hi to all !
For who may concern to setup an IR remote on Rern’s new achievements :
RuneAudio+R e2 & RuneOS - DIY RuneAudio+R e
Both of them use the new Kernel 4.19.x. who includes gpio-ir, not lirc_dev.
First you have first to install Lirc (it isn’t preinstall)
Then more or less you can follow the procigure as described here :
This changes must be performed :
1) In /boot/config.txt you have to remove Lirc line:
dtoverlay=lirc-rpi
And replace the line :
dtparam=gpio_in_pin=xx
With :
dtoverlay=gpio-ir,gpio_pin=xx
Note :
Modify the gpio xx numbers according to your IR sensor wiring.
2) In /etc/lirc/hardware.conf you have to replace the :
MODULES="lirc-rpi"
With :
MODULES="gpio_ir_recv"
That was the easy part.
The difficult part regards the remote configuration file (/etc/lirc/lircd.conf.d/lircd.conf)
The signals generated by gpio-ir, is slightly different from that of lirc_dev.
So you have to create a new configuration file.
To create your own configuration file, there are instructions elsewhere on the net.
Best regards
Stavros
s.k.
Postby eea123 » 21 Nov 2019, 13:26
eea123
