Is my new R Pi3 faulty
Postby ICLlP » 18 Aug 2016, 16:47
I just assembled a Pi 3 with a HiFiBerry Digi+ and metal Digi+ case and flashed a new SD card with runeaudio 0.3beta. I can't detect the Pi on the network using Fing and cannot connect at runeaudio.local. I can see a green LED on the Digi+ and a red LED on the Pi, but no flashing LEDs are visible, but it's virtually impossible to see inside the metal case. If I take it away and put my old Pi and Digi in its place it all works OK.
Any insight or advice?
ICLlP
Re: Is my new R Pi3 faulty
Postby Devox » 18 Aug 2016, 17:05
What's happening if you connect the SD, with rune on it, to a PC/MAC? Can you see any content?
If yes, and it is the right content, I would eliminate sources of failure and boot the Pi bare naked, just with the SD. No HifiBerry etc.
I also would flash a SD card with RASPBIAN, following the official guide, and see if it works.
If not, you got a faulty Pi.
If Yes, the failure is somewhere in your rune-installation.
Devox
Postby hondagx35 » 18 Aug 2016, 21:51
Postby ICLlP » 18 Aug 2016, 23:28
Good advice, thank you. I've established that it isn't booting up. I got this from HiFiBerry, which I'll try first.
No, you just have to change config.txt:
https://support.hifiberry.com/hc/en-us/ ... PROM-usage
I've just seen that this is what Frank posted. Thank's to all.
ICLlP
