When I browse a folder (Artist) with several records, the options of "Add and Play", "Add, Replace and Play" and "Refresh Folder" are cut off. The only option is "Add". This seems to be caused by the view able window now allowing scroll beyond the last album or song in the list to allow those options to come into view. The work around is just to add and then manually select the song in the playlist tab, but, it is not intuitive, and clunky.
Potential solution, default the selection dialog of the 4 choices to bottom justify rather than top justify with the item name, this will force all options to be visible.
If this is unclear, I can send some screenshots.
