Joy-It Display
Joy-It Display
Postby Paddy_B » 13 May 2019, 19:32
Paddy_B
Re: Joy-It Display
Postby Paddy_B » 13 May 2019, 20:22
Here is the link to the display:
https://www.joy-it.net/5-touchscreen-display/
Paddy_B
Re: Joy-It Display
Postby janui » 17 May 2019, 11:04
Hi Paddy_B,
I have had a look at the driver instructions. I have a feeling that a suitable driver may already be available. If you look in the file /boot/overlays/README you will find several touchscreen drivers which are already implemented as device tree overlays. You could try activating each one in turn to see it works with your touchscreen. You activate them by adding the parameters to /boot/config.txt.
You may need to calibrate it manually to match the screen size.
Re: Joy-It Display
Postby Paddy_B » 19 May 2019, 17:16
Hi Janui,
thank you veryy much for your reply.
Inside the display driver i found what i thought i need:
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
after editing the config.txt nothing works anymore.
Don't know what to do anymore and I'm afraid I have to choose another player.... :cry:
Yours,
Paddy
Paddy_B
