Just wondering about pi performance
Postby matt » 09 Sep 2014, 22:25
I am currently using a wdtv live (3rd gen) as a music server using the optical out into my denon reciever. While this works ok as far as reproducing music the the UI is painfully slow to the point of being almost unusable, and when set to random play there is a long gap between songs and if I skip a song it takes around 10 secs to stop playing the song and there is another long gap before the next song starts. I have approx 1.5TB of mp3, flac and hi res flac files. I assume its the sheer size of the library which makes everything so slow coupled with an underpowered device.
I want to avoid these issues with my proposed build.
The wdtv live has a Sigma Designs SMP8670AD-CBE3 processor with 512MB of DDR2 memory from four Nanya NT5TU128M8GE-AC chips spread around the motherboard.
How does this compare in terms of performance with a pi?
Does the pi have enough processing power to avoid these issues?
matt
Re: Just wondering about pi performance
Postby cmh714 » 09 Sep 2014, 22:55
you can dig up the stats on the Pi, but what I will say is I have >1TB of FLAC and HD FLAC and dont have any issues like you are having. YMMV
Postby matt » 09 Sep 2014, 23:21
matt
Postby skrodahl » 09 Sep 2014, 23:41
RuneAudio, especially with the latest 0.3-alpha build, is very responsive.
I have no experience with your Western Digital unit, but I promise you that you will enjoy RuneAudio immensely. It's built with audio quality in mind, and it's super easy to use. You can even control it from your Android device, or iPhone/iPad, using MPDroid and MPad respectively.
The web-ui is snappy, and it doesn't slow down depending on the uptime of the Raspberry Pi. Adding songs/albums to the playlist and removing them again, skipping within songs, pausing, playing, changing volume, setting repeat etc. are all instantaneous operations with absolutely no delay at all.
What you need to know is that by being built on MPD for organizing and playing music, RuneAudio will perform somewhat slower for certain operations that are not related to music playback.
The first time you start up RuneAudio you need to build the music library. That will take a good 20-30 minutes with a library that exceeds 1TB. As MPD builds the library, all discovered music is accessible and can be played with no performance hit at all.
Everytime you add music to your RuneAudio storage, you will need to scan the library again. This operation takes a couple of minutes, and does not affect overall functionality or performance.
I also find that with a large library (I haven't tried with a small library to be honest), the search is not exactly instantaneous. Any search will take four or five seconds.
Any MPD configuration changes, you will find those in the menu at the top right, will restart MPD. That also takes about five seconds.
To sum it up:
* Performance is excellent for anything that has to do with playback and playlist operations.
* Performance is good for operations that has to do with configuration changes.
* You may not enjoy the initial build of the library, but you're going to do that operation only once. I suggest that you connect your Raspberry Pi with an ethernet cable, at least when you initialize your library.
On a side note:
To achieve good results with Raspberry Pi sound-wise, you will also need a DAC. USB DACs are not a good match for the Raspberry Pi. If you are planning to use RuneAudio the same way as you're using your Western Digital, with optical out, I would recommend that you take a look at the HifiBerry Digi DAC. It's a DAC that is tailor made for the Raspberry Pi, that performs great for all files up to 24bit/192kHz.
If you don't need digital out, the HifiBerry DAC or IQ-Audio's Pi-DAC seem to be among the most popular choices. Again, for all formats up to 24bit/192kHz. The Pi-DAC would seem to have the best specs, at least on paper, and it includes a hardware volume control. They have different features though. I use the HifiBerry because it gives me an easy way to add an external power supply, and it sounds really great.
Supported i2s DACs in RuneAudio as of v 0.3-alpha
Screen Shot 2014-09-10 at 00.55.48.png (35.78 KiB) Viewed 3922 times
-skrodahl
skrodahl
Moderator
Postby matt » 10 Sep 2014, 00:47
matt
Postby Midnight » 10 Sep 2014, 08:33
In my experience the RPi is painfully slow when browsing through the library database (not just the file structure) with clients like MPDroid. It can take up to 30 seconds when opening an artist to view the albums.
IIRC such a library browsing function will be added to the Runeaudio web ui, so this may be slow, too. Loading times are much faster with a Beaglebone Black, but still not what I call responsive.
Playback won't be a problem for the RPi.
Midnight
Moderator
Postby skrodahl » 10 Sep 2014, 10:01
-skrodahl
skrodahl
Moderator
Postby Midnight » 10 Sep 2014, 10:30
Hi skrodahl,
how big is your collection?
I've experienced this delay on 2 different RPis and a BBB (while this one is faster). Tested in 2 different networks, while it works instant with my PC in the same network. Tested from 2 different smartphones and a tablet. Always the same: PC serves nearly instant, BBB takes some time, RPi takes an endless time. The RPi uses a Sandisk class 10 high speed memory card.
Only thing that comes to my mind: the devices also had to serve the album arts. But IIRC even without serving album arts the response is everything else than fast. After my experience I would not recommend a RPi for collections of 50k+ tracks.
Midnight
Moderator
Postby ACX » 10 Sep 2014, 10:54
Postby skrodahl » 10 Sep 2014, 10:59
-skrodahl
skrodahl
Moderator
