kernel & soundquality
Postby nixda » 13 Jun 2016, 13:56
besides the issues I permanently have ( )
I have one working sd-card.
But on this card/system, I inadvertently changed the kernel to "arch linux" (+ no option to go back)
Although everything sounds ok, I like to know, if the kernel does effect the soundquality, or is it just to enable specific hardware?
thanks
nixda
Re: kernel & soundquality
Postby hondagx35 » 13 Jun 2016, 16:11
Postby nixda » 13 Jun 2016, 17:35
thx Frank (would be much easier in german, but ok ....)
currently I don´t have my rune/pi device to look at, so just from memory;
In "Settings" , there´s an option where you can choose different kernels (rune-something as default + 2-3 others)
during scrolling on my mobile device I hit the "save settings" button - now this arch-linux kernel is active and the others disappeared from the pop-up
The error-message linked above:
no I did no update (except yours for the , which all the trouble started - but that´s many installations ago ;) )
I suspect it may be the cheap card-reader (mSD->USB), because everything is ok before I copy the playlists to var/lib/mpd .
I´ll check that at my next installation marathon. :mrgreen:
BTW the is recognized again, also.
Probably it´s crucial that everything is connected and running at the 1st (!) boot (no way if only correct on the 2nd, 3rd....?)
And (last not least) you have to let rune finishing updating the library before doing anything (just my guess)
setup is RB.Pi2 / rune04 / FiioE17 (dac)
nixda
Postby hondagx35 » 13 Jun 2016, 21:19
Postby nixda » 15 Jun 2016, 10:22
nixda
Postby hondagx35 » 15 Jun 2016, 14:01
Postby albert6720 » 20 Jul 2016, 17:29
Is it really work because i also have some sound quality issues. Hope it will work for me also.
albert6720
