Latest image
Latest image
Postby nzlowie » 15 Jun 2016, 02:56
Hi all,
I just installed my raspberry pi digi + board but Rune had no output for this..... i downloaded and flashed the latest image dated 21.03.2016, its running but still only the 2 options in mpd config. Pi analoge and hdmi, no digital.
Any ideas.
Thanks Dave
Sent from my SM-T800 using Tapatalk
nzlowie
Re: Latest image
Postby dunghnguyen » 15 Jun 2016, 04:31
It seems you have not reconfigured the config.txt. Do like these following:
- Turn your Pi off
- Take out the microSD card
- Put in the card reader plugging in the pc / laptop
- Use Notepad++ to open the file config.txt from the root directory of the card. You need to find the line having similar to "hifidigiplus" to remove the # in front of that line then save.
- Insert the card into Pi to boot again.
Hope this helps.
http://www.runeaudio.com/documentation/ ... t-settings
dunghnguyen
Re: Latest image
Postby nzlowie » 15 Jun 2016, 07:06
Thanks, easily done.
Working now! Thanks. Trouble is its got a hum on the output.... nothing at 0 output but there as soon as it goes above 0. Will try different power supplies but the thing that really worries me is the loud click when changing betwen the sources, eg usb audio and web radio.
Any thoughts on that one?
Thanks again Dave
nzlowie
Re: Latest image
Postby dunghnguyen » 15 Jun 2016, 08:34
Hi Dave,
Let discover more the Rune. You could find to enable the volume normalization in the MPD menu for what you are concerning.
dunghnguyen
