LCD display and buttons in Python (tutorial and code)
Re: LCD display and buttons in Python (tutorial and code)
Postby TommyBoy » 26 Jan 2017, 18:50
any one know where in the file structure i can find song playback info ?
like tittle ? play time, remain time ? resolution ? sample rate ?
TommyBoy
Postby hondagx35 » 26 Jan 2017, 19:00
Postby TommyBoy » 26 Jan 2017, 19:45
thanks so much.
however the numbers dont update ??
i hear the music play, but no time indicators move.. ??
update : if i change volume in the UI, and then ask the command as you suggest in the console
NOW i see changed time info..
can i get updated LIVE values via the console, with out need to touch the UI ?
and one other "thing" the JSON i get looks like yours, but nothing at all like the standards i can read about
here for example
https://en.wikipedia.org/wiki/JSON
TommyBoy
Postby TommyBoy » 27 Jan 2017, 18:36
No news / solution ?
The UI dont update either, try webradio whete they write the track they play, i need to change volume one up, and then down again, to get an update, same as with this json string,
Just too bad, i had a super idea for a display, but it just will not work, since this stuff is not live.
TommyBoy
Postby hondagx35 » 28 Jan 2017, 00:05
Postby TommyBoy » 28 Jan 2017, 01:03
i am sorry, I dont understand a single thing in this answer ?
WHAT exactly do I type in the console, to get that kind og cool info ?
please help ?
TommyBoy
Postby hondagx35 » 28 Jan 2017, 01:11
Postby TommyBoy » 28 Jan 2017, 01:23
OK it works in the console via putty.
but does it also work, like via a serial line ?
this way I can also access the console, right ?
by the way I dont understand the time, and elapsed in status ?
none of them reveal real length of the track ?
that is in "currentsong" info
but in secs
where do I find all telnet commands for MPD ?
TommyBoy
Postby hondagx35 » 28 Jan 2017, 10:06
Postby Yatsushiro » 28 Jan 2017, 11:14
Yatsushiro
