LCD display and buttons in Python (tutorial and code)
Re: LCD display and buttons in Python (tutorial and code)
Postby cceda » 27 Mar 2016, 19:26
Hi to all,
I have
RuneOs: 0.3-beta
RuneUI: 1.3-beta
Hw-env: RaspberryPi 2
is it possible to find somewhere full AUTO INSTALL - setup for i2s LCD 4 wire.
I use this connection with lcd
http://buzzthisnow.com/wp-content/uploa ... -2-i2c.jpg
but withouth sucess. :(
please help with some full setup manual. :shock:
thx. in advance,,
p.s.
I can locate LCD but the rest is not good!
[root@runeaudio ~]# i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 3f
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
cceda
Postby zzeromin » 28 Mar 2016, 02:39
zzeromin
Postby XploD » 30 Mar 2016, 20:07
Music taste:
Hi-Fi:
Mixer: Nady Audio MM-242
XploD
Postby cceda » 10 Apr 2016, 20:51
Hi to all again,
sorry for late response...
my status now is like this
RuneOs: 0.3-beta
RuneUI: 1.3-beta
[root@runeaudio ~]# systemctl start runelcd.service
[root@runeaudio ~]# systemctl enable runelcd.service
[root@runeaudio ~]# systemctl status -l runelcd.service
* runelcd.service - Runeaudio_I2C_LCD service
Loaded: loaded (/usr/lib/systemd/system/runelcd.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Sun 2016-04-10 21:52:15 CEST; 22s ago
Main PID: 978 (code=exited, status=2)
please give me advice how to fix this message " Active: failed (Result: start-limit)" :(
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- --
text on display still not working..
thanks in advance,
cceda
Postby cceda » 11 Apr 2016, 19:16
Hi to all again,
RuneOs: 0.3-beta
RuneUI: 1.3-beta
when I finish all steps... I got this
thanks in advance,
cceda
Postby jeroenrood » 17 May 2016, 10:03
jeroenrood
Postby TheOldMan » 02 Jun 2016, 03:00
Hi All,
I have a RP3 and 16x2 LCD, and I don't have I2C LCD module and the buttons.
I've wired, installed driver,... So I can write a script to show text message on LCD.
Can you help me, guide me to write script to show title of curent song, timeline progress, ....
Many thanks in advance.
TOM
TheOldMan
Postby janus » 18 Jun 2016, 17:35
janus
Postby TheOldMan » 19 Jun 2016, 16:58
TheOldMan
Postby hana » 21 Jun 2016, 07:55
Hi everybody,
I am a fan of runeaudio at all. now I am trying to little upgrade my install with LCD display, but without success...
I actually have RPI2 model B and rune 0.4 (also tried 0.3 with same results), here is the paste http://pastebin.com/0asq4ezM
I have adafruit 1115 LCD (I2C, adress 0x20)
I installedd python and GCC, install libtraries, and Xplode last version code
when i run demo file from Adafruit library LCD runs like a charm, all buttons is working and LCD too
but when I try to start Xplod. start.py (I modify the adress to 0X20 and disable the butttons), LCD did not work at all
do you have an idea where can be a problem?
I2C must be enabled, because demo file is working.
thank you for your help
or please let me know about some display 4x20 with buttons which actually works.
This thread is a little long and a lot of versions is in, so it is hard to choose the right parts
thx
hana
