LH Labs Geek Out 720
Re: LH Labs Geek Out 720
Postby ACX » 22 Aug 2014, 11:03
Postby cmh714 » 22 Aug 2014, 16:26
See the second paragraph in this link, but its a setting on the DAC. You hold the vol buttons down. Give it a try as it cant hurt any :)
http://www.audiostream.com/content/lh-l ... -amplifier
Postby franz159 » 23 Aug 2014, 21:57
I'm afraid the problem is in the dac itself.... I tried using it on my Mac with Audirvana, and it was systematic: no audio output when in a playlist I switch from "44.1" to "48" and vice-versa.
I ended up forcing Audirvana to always downsample to 16/44.1, which is not clearly a solution.
I opened a ticket with LH labs support.
franz159
Postby cmh714 » 23 Aug 2014, 22:31
Thats a shame. It looks like a nice device. Hopefully they work it out for you.
Postby franz159 » 26 Aug 2014, 19:22
This is not a solution for my dad issue, but for "casual" listening, is there a way to configure Rune to force a downsample (say to 16/44.1) on output?
I know this "denies" the whole point of having hir-es playback, but as a temporary measure it would allow me to experiment with the "global random play" rune option.
franz159
Postby cmh714 » 26 Aug 2014, 19:34
yes, in /etc/mpd.conf you can set the sample at something "static"
link for man page: http://linux.die.net/man/5/mpd.conf
audio_output_format <sample_rate:bits:channels>
This specifies the sample rate, bits per sample, and number of channels of audio that is sent to each audio output. Note that audio outputs may specify their own audio format which will be used for actual output to the audio device. An example is "44100:16:2" for 44100Hz, 16 bits, and 2 channels. The default is to use the audio format of the input file. Any of the three attributes may be an asterisk to specify that this attribute should not be enforced
Return to Compatibility list
