Library: make sorting case insensitive
Postby waves » 11 Mar 2015, 09:52
waves
Re: Library: make sorting case insensitive
Postby ACX » 11 Mar 2015, 15:44
Hi waves,
the UI just renders the response of the query to MPD, so please take a look if there's an option to change that behaviour.
Postby waves » 04 Jun 2016, 17:44
Very old reply, but I just now took a look. Is this the command that Rune invokes MPD when browsing folders in the library?
https://github.com/RuneAudio/RuneUI/blo ... o.php#L594
If it is then things don't look so good since
https://www.musicpd.org/doc/protocol/database.html
have no case-insensitive switch for the lsinfo command.
waves
Postby Orion » 08 Jun 2016, 22:38
Hi waves,
yes you are on the right line of code. In the new version of RuneAudio we are working on a different sorting solution that basically is decoupled from MPD. Obviously the current version is more straightforward, it simply takes what MPD says and route it to the UI. About the new version we are thinking of what is the best way to achieve our own management of lists sorting without penalize the performance too much.
- Embedded Hi-Fi music player
Orion
